Made in U.S.A. Loppers for Trees
gatlibs
N/A
I can't find mine. I'm thinking about buying a new pair to use. Stihl sells some made in U.S.A. ones at my local Ace Hardware. Does anybody know of the cheapest U.S. made Loppers with the largest throat for cutting limbs?
I don't need the ratcheting mechanisms. Those are like ice boxes in a refrigerator to me - just an additional thing to break first. Compound would be fine, but old fashioned single blade styles are fine with me.
AmericanMechanic
I know you're asking for US made, and i try to buy US made as well. If you're looking for premium, it might be felco 22.
seanb02
The Farm
Not trying to start anything but the biggest question is does the COO really matter if it is quality?
You mention that compound would be okay but primarily focusing on single blade style. Unless cutting very soft limbs the biggest throat you can find is only going to hinder you unless you are the hulk. Compound will be better in a lot of ways.
What exactly are you using the loppers for? Trimming fruit trees or general use around the ornamental trees? Or general brush work after felling trees around the property?
Toolchat
VACA and Hickok for made in USA.
I agree with AmericanMechanic. If you want premium, go for Felco but you’ll pay premium price.
If you want quality without the Felco price, look into ARS but the loppers are not made in the USA.
I use ARS but my gardener uses Corona. Whatever cuts without the loppers falling apart and hurting myself, that’s good enough for me.
bob15
Northeasten, CT
I couldn't find any USA-made loppers that I liked and wound up going with German-made WOLF-Garten Telescoping Anvil Lopper, part # RS900T. They can be found on amazon. Pricey, but I like the ability to make the lopper's handle longer for both better leverage and to help make my arms longer if needed.
For small twigs and pruning, I have Felco F-11. If you are a lefty, Felco also makes a version F-9.
flushcut
Delavan WI
What exactly are you cutting? Dry wood? Green wood? What size limbs?
Felco, Bahco, Corona, are about the only brands to buy. And wood above 1" is better cut with a saw than a lopper. A saw produces a better cut and faster healing of the wound. Read up on proper pruning cuts.
lis2323
I agree with the others. Quality first.
Mine are all Felco and Corona.
rlitman
Long Island
Stihl hand cutters are not USA made. The hand pruners are made by ARS in Japan (still, IMNSHO, they're the best you can get in the world). I forget who makes their loppers right now, but they are excellent. If you buy it Stihl branded, you get Stihl's lifetime warranty.
Jameson makes my choice of pole saws (and pole pruners). There's also Silky.
Felco makes an excellent hand pruner, but they're not as far ahead of the clones at a tenth of the price to make the real ones worthwhile in my opinion. Corona is not what it used to be. Bahco and Sandvik both make excellent tools in Europe still.
I prefer an anvil lopper for wood, or a saw for dead wood that's gone crunchy. NONE of the above companies make a good anvil lopper that I've seen. They all make bypass loppers, which are what you want when you need a clean cut across something green, but bypass is not that great on actual wood. For that, I'd suggest a Seymour anvil lopper. This same mechanism (and I believe OEM) is sold as Craftsman (if you can find it), and Ace branded (Ace is nice, because anything with their name on it carries the Ace lifetime warranty), plus several others.
Treeman
Anvil loppers tend to crush the stem and injure the cambium more than bypass loppers.
The main U.S. manufacturers is Barnel, and maybe Hickok, and VACA. Like Felco is the standard for hand pruners, these companies are the standard for orchardist loppers.
Arboristsite sometimes claims that Stihl is imported ARS. The Stihl Precison Series I have used appear to be U.S. made Hickok.
I'm currently using Barnels.
https://www.barnel.com/loppers.php
I cannot i.d. the Hickok Company. They are very similar to Barnel, but not exactly.
Also cannot i.d. VACA (maybe Fred Marvin too). Again similar to the others, but slight differences in blade forging and handles.
Bahco, Felco, Fiskars, Vesco, and AMLeonard are others to consider.
G
gatlibs
N/A
I generally use on green when felling trees or clearing brush. It is more home usage, but almost never at mine. I thought that I left them at my grandmother's when I was clearing some overgrowth, but I cannot find them. Sometimes it is Deadwood, but very rarely. I could cut 2.5"+ with the old set by bracing one handle to my side and pulling the other handle with my arms. Sometimes, it is much more convenient to carry a set of Loppers than it is even to carry my 16" chainsaw. Also, it is great to give the Loppers to an assistant while I am using the chainsaw. It is very difficult you cut one's self with loppers.
I think that the blades on Stihl are Sharpe enough that they cut what fits into them. My Craftsman was about a 3"+ throat and I couldn't cut everything that fits into it, but they were so large that it didn't matter.
I don't mind the type for anvil, but Ithat angle prevents much from fitting. I could always use my Stihl polesaw to cut close to the trunk for visual cuts. Sometimes, I do prune.
I am very rigid about buying U.S. manufactured.
Fabricator
Kent... WA
+1 for Barnel
Wore out a couple of sets of Home Depot no-name and Corona bypass loppers for ORV trail clearing and maintenance, which deals with a lot of scotch broom around here - that **** gets hard to cut with a lopper when it gets big.
Bought the BR7000 ratcheting version two years ago, and they go through big scotch broom with ease. Can get replacement blades and anvils for them too, although I haven't had to yet.
dr_clyde
Holland, MI
Huh. Learned some stuff today. I had no idea you could spend so much on loppers.
Here I've been really, really happy with my Fiskars I bought for $25. I never knew there was such a market for ultra high end loppers.
RCL
I clear a lot of cedars and have not had good luck with my last couple of Fiskars loppers.
Blades seem soft on the new ones.
Have a set from about five years ago and they have held up well.
Now using Barnels.
G
gatlibs
N/A
I decided to go with Stihl since it was the most quickly available made in U.S.A. option.
rlitman
Long Island
I don't blame you. Stihl's hand tool quality is right up there with Felco, and parts are equally available, plus you have a great warranty and local dealer support that you don't get with Felco here.
The only thing I'll say is that as I pointed out above, bypass loppers have limited uses. They're made for cutting only live materials, and preferably green stuff at that. I prefer bypass hand pruners, and anvil loppers, but you and I may not be cutting the same sorts of plants.
Treeman
rlitman,
I generally have little trouble on "live" wood with good bypass loppers. But I agree that dead wood material is much more difficult and often a saw is more appropriate. I think you are correct about results varying according to what you are doing with them.
A comment about the expensive Felco loppers. Avoid the models that have blades without much curve to them. I find that anything above a small diameter tends to push out of the blades instead of grabbing and cutting well. I was very disappointed in the pair I bought (model 21). SORRY FOR THE GINORMOUS PICS.
VS.:
G
gatlibs
N/A
Generally, my use is almost exclusively on live material. When I fell a tree or am cutting back thick brush it is more handy to me to look than to use my chainsaws.
Also, a great use of loppers is letting a person that I'm helping use those on the smaller stuff while I move to the next tree or bush et cetera. I've been pretty pleased with them from trimming a bush briefly. I might buy a second set of shears from Stihl to accompany my Craftsman telescopic ones.
jonshonda
Wisconsin
I was on the same quest as the OP for loppers and thought really hard about the Stihl versions, but just couldn't justify the price as I was also buying a pole saw at the same time. Even though they aren't as pretty at the Stihl, I bought some nice Fiskars and am happy with them so far.
orangeblood
Texas
I am guessing Treeman knows more about this than I do, but I cant disagree more with the criticism of the Felco 21. I have used this lopper for 20+ years and have never had the blades push out when cutting green branches that reasonably fit between the blades.
Felco is very well made. If you anticipate using it more than once a year (for light trimming) this is a "cry once" purchase.
ATC
VA
I have Fiskars with the geared deal on it. They kick some serious ***.
My mother is a self-employed landscaper, and this is what she uses. She likes 'em...and so do I after using them a few times around the house.
