Made some quickie copper vise jaws for my Wilton
dr_clyde
Holland, MI
I hate the serrated jaws that come with the Wilton vises. They do grip the work well, but I don't know why anyone thought it would be acceptable to leave a scarred, sharp, jagged finish on your part. At least on the tradesman, the jaws are reversible to the smooth back side. But, on the machinist models they are centered by a little boss on the jaw recess making them one way only.
All the vises in my shop get copper soft jaws. I never have an issue with them slipping, and they can be resurfaced several times before they need to be retired. Plus they are nice for welding.
Banged these out on the Bridgeport this evening.
EdT
North Georgia
Those copper jaws are really nice!! Do you find any advantage of using copper rather than aluminum?
D
dr_clyde
Holland, MI
Copper is more dense, so it's more durable and you won't deform them as bad when you need to crank down on something.
sanddan
Oregon
Very cool. What spec copper did you use? I checked McMaster-Carr and they have a "Easy-to-machine 145 Copper" that comes in 1/2"X 2" bars among other sizes. Not cheap though.
D
dr_clyde
Holland, MI
I used 110 copper bar from McMaster. In case you were wondering on cutters I used a CTD drill for the thu drill and an Imco 4 flute carbide endmill for the counterbores. Faced to thickness with a Seco Carboloy 6 insert face mill. It machines fine provided you use the right speeds and feeds. I used Trim E206 soluble oil in a squirt bottle for lube.
zkling
Technically density has nothing to do with the stiffness or ability to resist deformation.
D
dr_clyde
Holland, MI
Ok, density is the wrong word. But my point is the copper is more durable than aluminum. Whatever the properties are that make it so.
383 240z
Findley Twp. Allegheny Co.
I've got a chunk of A360 here for that same project. However might use some Aluminium bronze I have left over, just to be different. Thanks for the pics. Looks great. Keith
exmaxima1
Midwest
Aluminum bronze might be too hard and slippery for jaws. Similar problem with many brasses. Copper seems to be better at gripping.
tarbellb
Oregon
Some junkie is going to steal the vise, try to pry the jaws off with a rusty piece of rebar, ruin everything, then ditch it in the alley.
But until then, those look dead ****. Well done.
Ign
Butte Peak ND
Thank you! I've been wanting to do this forever for the same reasons. People who don't know any better tell me it's stupid, wasteful, copper is too soft etc. All incorrect.
I just never seem to find the time to make a set.
I agree, serration marks in the work are never acceptable.
kazlx
Tustin, CA
Personally, I've never had serrated jaws on any vise I've owned. If they have them, I grind them smooth.
CastleBravo
Lynchburg, Virginia
I wonder if one of you fine gentlemen would be inclined to mill a set for a guy like me? Dimensions provided of course.
sanddan
Oregon
I checked out my Columbian vise and there isn't an obvious way to remove the steel jaws. It looks like they have a rabbit joint between the vise and jaw without any screws that I can see. Not sure how to remove them.
D
dr_clyde
Holland, MI
I know my Columbian has the same tongue and groove jaw. I believe they are pinned in. If you can manage to get the pins out, you can replace the jaws. Not worth it IMO. I use mine for taking apart pipe and other dirty jobs where it doesn't matter if the jaws mark the work.
