sierradmax
So here's my problem. I have a bobcat with some bad bushings. Pins are easily replaceable but the bushings are tough to replace. You have to cut the welds, remove bushings and re-weld new.
Another alternative is line boring but I'm having difficulty finding a company to weld & bore 1.25" holes. Seems a bit too small for the machinery normally used.
I have 4 bushings that need to be replaced and two lift arm rod links. Essentially, $1,100 in parts new, minus labor to install. I'm curious if there it a mag drill that can use 1.25" bits or cutters with a throw of over 4.5"? This way I could puddle weld the holes, set the mag drill on one side and drill through both existing bushings for a clean, straight hole.
