magnetic dial indicator bases
vette-kid
Navarre, FL
What's a good one? I have an older one and the magnet is great on it, but the thumb screws on the arms are a serious PITA to set. I find that the connection at the dial is often in the way making it difficult to get the angle I want and the "elbow" seems to be getting loose and doesn't hold as well.
What do you guys use/prefer? This is mostly for engine work (cam degreeing, lifter rise, etc), checking rotor run-out, or whatever other random use pops up for it. I find Im using it a lot of odd angles.
larry_g
oregon
So lets take another tac here, give us a budget and we'll tell you what to get, it obvious you don't want to spend money for top tier stuff.
lg
no neat sig line
Provincial
Near Salem, OR
I have a Fowler flexible base that I love. Here is a link to a set with an indicator included:
http://store.greatgages.com/servlet/-strse-3411/52-585-500/Detail?gclid=CIPksZaIsL8CFYqPfgodlSkAVA
I don't know the quality of the indicator in this set, but the base looks just like mine.
To use this base, loosen the lever just above the magnet and move the articulated arm into the position you want it. Then tighten the lever again. A cable inside the links places tension on them to lock them in place. Once you get the hang of setting it, you will never go back to a regular indicator base!
There are other sources for this type of base. I've seen some for less than $40.00, but I think that this is one item where you get what you paid for.
V
vette-kid
Navarre, FL
lg
no neat sig line
I suppose I just wasn't expecting to see them well over $100 for some. I'd probably prefer to keep it to $75 or less if I can. But if that just wont buy a quality piece, then Ill spend what is needed. I like to keep cost down, but Im not going to be foolish about it. The one I have now is an old used one I picked up for pretty cheap when I had never used on before. Now I find myself using it more, its time for something better.
Thanks for your input :thumbup:
V
vette-kid
Navarre, FL
interesting! Thanks for the link, ill keep an eye out for those.
I honestly figured the base would be an item that could be had relatively cheaply. I just never figured you would have to spend $100 for a quality one...not the first time ive been wrong though.
Strouty
Southern Maine
www.use-enco.com
Sign up for the emails at this site, almost every tuesday they will send you 20% off or some other deal. Use that code to buy one of these, it will work on the sale prices as well.
dsimatt
I've got this one herehttp://www.matcotools.com/catalog/product/DIM10B/reviews/1/
I broke one of the clamps thou and need to replace the clamp or set so who makes the set because matco is the rebrand king.
larry_g
oregon
If you look in the MSC, Enco, or McMasters catalogue you can find parts and pieces for indicator bases. It is entirely possible to replace just the arm on your base or just the snugs. I find at swap meets often someone will have a box of miscellaneous indicator base parts. I will buy the lot if I can so that I have the parts and pieces to make up what I need to fit the job at hand.
lg
no neat sig line
Monte
Germany
www.hoerger-gaessler.de
Provincial
Near Salem, OR
Note that the link is for the base AND and indicator for $86.70 + shipping. If you want an inexpensive version, Summit has an asian knock-off (just the base) for $37.97 here:
http://www.summitracing.com/parts/cbi-50220?seid=srese1&gclid=CJD-ltKnsb8CFY17fgodZaEAOQ
rodm1
Noga is the best if it doesn't work I use a flex Starret but not very ridged.
383 240z
Findley Twp. Allegheny Co.
I've tried a bunch of the DI bases, I finally broke down and spent $115 on a Noga. I wasted so much time fighting with the cheap ones. I should have done that years ago. Keith
Givl Reggin
Hawaii, USA
I know I sound like a broken record, but...
If you are making your buying decisions concerned about the price, you are going off in the wrong direction.
Tools are something you're going to have the rest of your life; buy once, buy top quality and buy a name brand that'll be around in 20-years to honor their waranty should you need it.
V
vette-kid
Navarre, FL
No worries, I appreciate the input. Don't take this the wrong way, but you must be more well off than I am...I CANNOT make a purchase without putting a budget on it. I do want quality, but even quality has a budget. I simply cannot afford to make each purchase with a "money is no object, get he best available" mindset. If that were the case, I would drive a Veyron and live in a castle. But alas, money is an object. So even for quality items, there MUST be a budget. I could buy better ratchets, but I refuse to believe that you have to spend $100 on a ratchet, there are quality ones out there for $30-$40.
Im sure I could spend $200 on a base, but after some looking, I feel confident that $75 will get me a quality tool. I am still shocked that it takes that much, to be honest.
Strouty
Southern Maine
A cheap magnetic base can't be compared to a cheap ratchet. If your budget won't allow for the noga or something in that price range, just buy a cheap one. I am willing to bet that the cheap ones are all the same quality just have different brand names.
AlexNGreen
Minneapolis, MN
I was in the same boat as you are now and messed around with the flexible mag bases but kept my eye on eBay and scored a Noga for $50. It was the best purchase made. Everybody that sees the Noga wishes they had one. I would wait and up your budget or be patient and keep an eye on eBay.
383 240z
Here is a heck of a deal on a NOGA!!!! The 20% off and free shipping ends today at 11pm EST!!!!
Fowler indicator
http://www.use-enco.com/CGI/INSRIT?PMAKA=KK890-9824
$25.99 - 20% = $20.79
Noga base with 70lb mag
http://www.use-enco.com/CGI/INSRIT?P...PARTPG=INLMK32
$60.95 - 20% = $50.36
Free shipping $71.15 Not bad for a good tool.
You could upgrade to the 176lb mag version for $105.95-20%=$84.76 That's the one I have, I use it 10-15 times a day and LOVE it. I have no idea why I suffered with the other type of mag base for so long. Keith
dsimatt
lg
no neat sig line
My snap on guy ordered me a OTC base, arm and 2 clamps for $40 so I'm gonna roll with that for now.
