magnetic tape measure
rmsg0040
Toronto
I am looking at many different brands of magnetic tape measures - 25 feet.
I need it strong enough so that I can suspend it vertically 20 feet on its own while I am on a boom or scissors lift.
Milwaukee and Klein seem to have a good option, but the Klein is hard to find. Milwaukee is readily available.
Any recommendations?
Thanks
Jim Johnstone
Brantford, Ontario
Hey man, not sure exactly how strong the magnet is, but I have a Mastercraft magnetic tape from canadian tire that I bought like 10 years ago and still use daily. I'll try sticking it to the ceiling at work tomorrow and see what happens haha.
R
rmsg0040
Toronto
Let me know, I have had 2 drop and break so far, one was magnetic and the other was regular
Hopefully the one I get lasts
engineer2
Chicago burbs
Look at Komelon Many models have a nice magnet on the end and the back side is a vertical scale. My favorite tape measure. I have two. Availalbe from amazon.ca .
Rarified27
Between PA and NJ
Milwaukee's magnetic tapes are over-engineered garbage. The small magnet in the tip is centered, limiting contact points. There's a second magnet on the blade for pipe measuring, but it's useless on non-ferrous metals. The tape lock isn't firm, allowing the slightest back pressure to move it. All of the ones I've tried in stores have the same tape lock problems as well.
Also, the first inch of the Milwaukee tape is almost unreadable, as it's covered by a massive plastic tab and the base is so thin, the tape tends to fall over when measuring things like lumber and pipe where you need the tape to stand alone so you can mark the material.
I prefer the Kobalt magnetic. It has two magnets that hold much better than the Milwaukee, a firm tape lock, the same vertical measure on the blade back, doesn't make the annoying plastic whistle produced by the Milwaukee tape with a wide rubber base that keeps it upright and a single, centered blade top tab on the hook unlike Milwaukee's two toward the side, to you can actually engage the hook from the top and use the vertical scale on any size/type pipe, as the Milwaukee hooks won't catch anything less than 1" and again, the second magnet is useless for pvc, aluminum, copper, etc.
If I hadn't received the Milwaukee tape as a free gift with an M12 purchase, I would have returned it.
The Kobalt also has the Lowe's lifetime guarantee/no hassle replacement.
Ign
Butte Peak ND
I'm with Rarified, my 25' Milwaukee was demoted to my truck as an "at least you have a tape at all times, and you don't care if you lose it." It truly is over-engineered. As a result it's also very heavy, so I wouldn't think it's a good candidate for trying to hang anywhere.
dnschmidt
Phoenix, AZ
Excuse me. The fact that a magnet doesn't work on non-ferrous metals surprises you? I must be missing something here.
R.Anderson
Wisconsin
Wonder if the other tape measures he has work on non-ferrous metals seeing he is only picking on the Milwaukee's tape for that problem. :lol:
Rarified27
Between PA and NJ
Ok, I see how my original post may seem confusing- no one expects magnets to grab non-ferrous metal (thus, the term).
I'm pointing out Milwaukee's second magnet as a waste where it's positioned inside the blade curve because the top fins of the blade hook won't allow it to sit flush, so the magnet is worthless, since the fins are designed to grab the material anyway (again, over-engineered).
The Kobalt tape I mentioned has a single fin on the top, which centers itself on round or square stock and uses it's second magnet on the tip, where the extra strength is appreciated when you have to measure something at a great distance across or above, where the extended blade weight would pull a single magnet away from the material.
Looks like Milwaukee is updating the design I don't like, so I'll be curious to see if there are any improvements.
http://toolcraze.net/new-milwaukee-magnetic-tape-measures-finger-stop/
Know Wosad
I have the Komeleon. It's not strong enough for that. Getcha a rare earth disc magnet(nickel sized) and stick it in between whatever you buy as a "jumper".Those discs stick HARD.like 20-30 lbs of force. Get a roll of 10 because you aint getting it back if you stick it to a beam or ceiling.
Hell get 100. Make some saw guides, alum straight edges and stuff. I use them all the time for jigging.
http://www.ebay.com/itm/10-100pcs-1...hash=item3f47577a9f:m:mnhQi8gnC-S7vPMMSdxS9bw
tarbellb
Oregon
I use the Komelon Mag-grip, love them.
Maybe not the most resilient, but they are excellent tape measures. They arent as beefie (over engineered perhaps?) as a Milky or Fatmax, but still pretty durable.
Oh, and they will absolutely hold themselves vertical. Just be sure its locked on first.
Actually, I bought a box of 30 once on Ebay. Got the price down to $4.**/ea, still have 20+ laying around for the rest of my life likely.
Saying that, the Kobalt Mag whatever looked like a pretty good tape as well, specially if it has any kind of warranty.
Rodbuster56
Chicagoland
I had the Milwaukee, and i agree, it is poorly designed. It is setup so that you have to put the tip of the tape under the object being measured, in order for the magnet to "grab". They made a tape before this model, that actually had the magnets positioned so they would work, but for some reason, changed the design.
FigureItOut
Bentonville AR
OP asked about the Klein also. I happened to have noticed it at HD yesterday and almost bought just cuz. Anybody have one?
Sent from my XT1575 using Tapatalk
jt777
Canada
Milwaukee are my choice. If they made them as wide as a fatmax they would the best on earth ever. Can't comment on use of magnet cause i use for 98% woodworking.
Rarified27
Between PA and NJ
Following up...
Milwaukee has made several positive changes (IMO) to the updated version of their tapes (and one huge step backwards).
The base is now solid enough to not tip when you let go of the tape to mark something, the annoying whistle when retracting is much less abrasive, the claw like hook has been reshaped to fit tight spaces (and not get caught on everything), the tape lock actually holds and the first inch of the tape (on top) is now much easier to read due to a smaller hook fastening plate.
One more change I would have liked to see was the use of a larger rectangular magnet on the blade tip or at least two smaller ones (like the Kobalt in one of my above posts) instead of the one centered magnet.
The huge step back for my use is unlike the previous version, the new tape has the magnet mounted in the hook fastener, which extends back over the tape, so you can no longer measure any kind of round stock because even if they had included the second magnet like the previous model, the plastic tab would still push it away from the tape and the top hooks aren't centered, so you can't even use pressure to hold the tip in place.
With the exception of the above gripe, I really enjoy this tape now. I'd consider cutting the big plastic piece off with a dremel to make it more functional and lose the magnet in the process, but tapes have worked just fine without them for years.
alien
Kobalt lifetime warranty. I am an electrician and use that feature all the time. I have picked up dropped wrenches and stock for 10-20 feet up on a lift with the magnet.
Only problem with the magnetic tips is they attract every little piece of metal scrap there is!
WhiskeyRanger
I use the (old style? Bought it 2 years ago.) Milwaukee and have no problems with it. Of course I'm an industrial electrician, so some of the issues that were brought up never really affect my usage.
