Main breaker dilemma
83rdracer
Canton Ohio
New guy here and hope someone can help. I have a newly built detached garage 24x32 with a 100 amp sub panel. Because the electrical run from the house is over 120ft I ran 1-1-1-2 cable to the sub panel. Now I have run into a problem where the 100 amp breakers will only accept 2wga wire or smaller. Any ideas???
lonestardiver
I have seen it where the ends are shaved or trimmed down enough to fit into the breakers...
jeepxj
Bert_
NW Iowa
What kind of 100 amp breaker only accepts #2?
Pretty much every one I've seen will take 2/0.
Chuckster in NJ
Hunterdon County NJ
Is this a panel with a factory main breaker installed OR did you grab a 100 amp breaker and "back feed" it after you stabbed it in?
BTW! I’d have never had a problem with a 100 amp main accepting a #1 AWG wire.
BD1
north side
Buy a 100 Amp disconnect switch. Tie in service to switch then run wire to panel
What is the Brand and model of the breaker?
:wtf:
wrong wrong TOTALLY WRONG!
NEVER do that... unless you want a fire...
