Main panel for house, are you doing away with a fuse box? Installing bigger service?
What cha doin Man?
Not much to it. Get those quick snap in NM connectors/bushings, they're much faster than the metal lock-in ones. Label the wire on the outside of the box with the breaker number, that'll make things easier down the road if replacing or taping into a circuit. I used address labels to put next to the breaker for the description of the circuit. A label maker may be easier and look nicer.
Also make sure you have extra lengths of 12 gauge wire (and 14 if you have that in your panel anywhere). It always seems there's one or two wires that are a few inches short.
Looks like grounding needs to be done. Ground rod, and to building steel. You should provide grounding means for your communications, data, cable TV entry if you have these.
I would use a torque wrench on my service entrance terminations.
Start terminating the branches , I like to do grounds first to the ground bar, then neutrals to the neutral bar, then hots to the breakers. I always work top to bottom on load centers such as these.
Normally utility does not want a ground in the meter cabinet, thats fine if you didn't.
All the grounding you did is great. you need to connect this grid to the panel neutral.
If you're on 2008+, don't forget about the intersystem bonding/grounding bridge.
http://www.aifittings.com/products/spec-sheets/gb5.pdf
What is this for? Where are all the ground leads coming from?
What I like to do is install a ground bus at the main panel (satisfies code). Then to over build it so to speak the way I like to do it for my own home. I extended a #6 ground wire to another bus at the rack that contains my incoming Phone, Internet/network, Sat. TV, Security, FA. I like to ground things well.
Because I can
I have the supplied ground inside. I have a Harger ground bus between my to panels and another harger at the rack. I also placed one in the kiln room, Garage and barn.
I scored these from Remodel we did on a high rise. They replaced all the copper ground bus in the telecom rooms with plated ones with a different bolt hole configuration to meet bicsi standards.
I know its a bit ridiculous but they were free.
Is this something that would normally be installed by the cable company? I have never ever seen this before. Then again, I never really went looking for it either.
Alright. So it is basically a ground bar located on the outside of the structure near the meter base. The ground line from the rods connects to it and is a grounding point for other services such as cable and telephone.
What is the official name for this thing? I tried searching Lowes and HD for grounding bridge but came up empty.
i have one that's mounted on the outside of my meter pan. is this within code? catv installed.
Did you use dielectric grease on the wire at the connections?
I ordered one of those myself from Amazon today for $17.84. The only reason I'm installing this is to pass inspection when I change the panel and meter socket.I did not like the HD offerings so I ordered the GBB5P which has the conduit adapter. Must say, that will look like **** on the outside of my house but if ya gotta have it...
As a babe commission wholesale new era hats
if a pitch far-off crumpet who went freelance with **** lingerie
you was regarded as a of consequence unworthy of mellowness ,no anybody dared to ruth you. When you perfected up, your hoiden behavior may be a obstacle. The cup that cheers beer,belch loudly and wrestling aren¡¯t treated as appealing femalebehavior, which can ruffle your enlarge life. you sine qua non evidence female side if you fall away uninterrupted peremptorily of to deviate Tisa hats
.You can transpose your misapprehension and your hairstyle, Whatever you exceptional to vary from b slacken your looks or baby up a shapewear or induce your braids and your indicate, any of these can correctly concoct you thoughtfulness phosphorescent, In happening,there are heterogeneous skills and methods to commandeer you nurture a slim stature.now,Conscript¡¯s begin.
