Question(s) for sparky's - - - - friend's mom just had new house built in Joplin, MO after tornado. It's slab foundation with main electrical panel on back wall of attached 2 car garage.
However, more I look they really skimped on house build as just single light bulb fixture in 2 car garage, light switches outside of rooms or on wrong wall when entering room, largest breaker in panel was 30 amp, cheap screen doors with no latches, etc. This is disheartening as she had all-brick home prior to tornado which was very nice and in excellent neighborhood.
Biggest screaming problem(s) were when she told me 1 yr old house was having breakers trip during normal operation of house!! Also, the main electrical panel does NOT have a master shutoff (see pic below)!!
Living room (largest room in house at 14'x20') had ALL it's entire electrical outlets and lighting on one 15 amp AFCI breaker (see pic below of Eaton - - 4th from bottom on right that is turned off). Owner is 80+ yr old and has normal 3 or 4 lamps in room, approx 40" LCD TV, and can lights in ceiling (ie minimal load in my opinion, but unusual that 100% of largest room was on 1 breaker). That breaker had been tripping frequently according to homeowner, which darkened the whole front of house and killed the TV. Living room breaker tripped the day I was there so I upgraded breaker to 20 amp.
Kitchen has both a electric counter-top smooth surface burners, and a seperate electric oven. These are both on individual 30 amp double-pole 240v breakers. Counter-top burner has been tripping the breaker under normal operation - - - shouldn't that breaker be either a 40 or 50 amp?? What about the oven, I'm thinking it too should be bigger than 30 amp.
Furnace is natural gas and looks properly installed. Air handler in attic is insulated and also has insulated ducts in attic to individual rooms. A/C compressor on outside pad is Concord which my research shows is low-end Lennox brand (see pics below). The A/C only has 30 amp breaker but homeowner said it has not tripped breaker yet, but really hasn't fully loaded it since moderate temperatures.
QUESTIONS:
1) How can that main electrical panel be code without a single-throw shutoff??
2) What amp double-pole breaker should be installed for counter-top burners, oven, A/C, dryer (these now are all 30 amp double-pole 240v breakers)??
3) Any comments whether Concord air conditioner unit is any good (only 13 SEER)??
4) Any undue risk for 20 amp AFCI breaker I replaced for living room??
5) Should correction efforts be aimed at City inspection office, or start with the builder/electrician??
QUESTIONS:
