cebarker69
- Joined
- Jan 27, 2013
- Messages
- 1
I have a summer home in Colorado where the winter temp can drop to -20 degrees F. We have a propane boiler in the garage with the condensate tube draining into a floor drain to the septic tank. The flooring is heated slab both in the garage and house.
The heat in the vacant house is left on in the winter at 50 F. Last week I made a trip to the house and was surprised to find the main sewer pipe frozen for many feet outside. I was told that this could happen when a house is left vacant in the winter and the heat on because the boiler condensate flow is so small. A plumber suggested installing a small lift station to increase the boiler condensate flow rate and thus avoid the sewer pipe freezing. This sounds good, but I was wondering if there might be other options to consider besides turning the heat off in the winter and draining the water pipes.
