Steve Tatalovich
Gents,
Im finally getting to the point where im installing pex in preparation for my concrete. Realizing I only have one shot at this I want to make sure I get it right the first time.
Facts:
Barn size 3200sq ft
Im using a wall hung Lochinvar Knight boiler WHN085
I have two zones, Zone 1=2100sq ft zone 2=1100sq ft
Two manifolds 1 is 7 loops the other is 4 loops
using a lochinvar hot water storage tank 20" diameter
My manifolds are mounted about 32" from the finished floor to the top of the manifold.
Issues:
I have limited space, (which most of you will probably find more than adequate)
65" wide X 8' tall space for manifolds boiler and all the other stuff.
Notes about the attached picture:
The electrical panel is moving to the left quite a bit to create my 65" opening.
The hot water storage tank will be on the right and is the right side of the 65" opening.
Questions:
Is this space sufficient for my needs given the manifold height or should I lower them?
How close can I put my manifolds? They are 1 1/4" outlets, located on the right side of both manifolds.
I have attached some pictures of my progress also so feel free to comment if you see issues.
Thank,
Steve
Facts:
Barn size 3200sq ft
Issues:
Questions:
Thank,
Steve
