What are you guys doing to maintain your lifts?
Looking through the manual of the HD-9, they say to use WD-40 on all the rubbing blocks but WD is water based and weak IMO. Is there something better to use like silicon spray that would work better?
Is there any need to add trans fluid at anytime if no leaks occur? I can't see how much is in the reservoir as it's black.
What's good to use on the cables?
It says to replace the cables every 3 years. Anyone doing that? If so, how expensive are they?
Also, on my manual, it says mine is an HD-9-C. I've noticed others here saying theirs ended with a B. What's the difference??
Thanks,
Bob
Thanks,
Bob
