Make a brake pad spreader!
03protege
Louisiana
Well if you read my pressurized brake bleeder thread you probably heard me mention I am doing my families brake jobs and the list is growing :willy_nil
So naturally I have been looking/buying brake related tools.
My biggest pet peeve of brake jobs is bleeding the brakes, now that I got that handled I decided to focus on my second least favorite part which is retracting the brake piston. In the past I have always used a C-Clamp and HATED it but I didn't (and still don't) want to drop $30-50 on a sweet pad spreader. I was contemplating making a socket driven one but I didn't feel like welding or going to buy the hardware.
Anyway in the middle of the brake job, the point at which I was suppose to go dig for a C-Clamp, I had a vision. I couldn't get it out of my head how much the brake pad spreader looked like a caulk gun.
http://www.amazon.com/dp/B0009OR8V6/?tag=atomicindus08-20
There is actually several zillion caulk guns that use that same grip/mechanism. http://www.amazon.com/dp/B0002YTSYS/?tag=atomicindus08-20
Then I remembered I had a caulk gun stashed away under the work bench I hadn't used in 5 years. :evil:
I zip-tied the grip in case I got carried away with the angle grinder.
A few seconds later..
When I have the time I am going to modify it by making the plunger smaller so it fits inside of the piston and I am going to make the part that catches on the caliper smaller so that it fits a little better in different scenarios. I also need to shorten the rod as the brake pistons don't need anywhere near that amount of travel.
:beer:
Vegaman_Dan
Pacific, WA
That... shouldn't work. I mean, that's just too cool and easy. It can't be that simple.
Does it take a lot of squeezing to push the piston back in? I always use a C clamp so I don't know the effort needed.
Super Mech
Bronx,NY
No need to modify the plunger, just put one of the old brake pads in between the piston and the plunger.
03protege
Louisiana
It is a two hand operation and if you have weak or arthritic hands it may not be the best route, but it took maybe 5 "pumps" and the piston was fully retracted. About 10 seconds total. The different caulk guns have different drive ratios I believe mine is about 8:1, the lisle one is 26:1 so it should much easier.
kbs2244
Super mech has the right idea.
Just leave the inside pad in place and push on it.
If you are worried about carpel tunnel, they do make pneumatic caulk guns.
I have a less than $5.00 HF, screw type spreader.
It works, but it is slow.
This may be in my future.
Nice hack.
Tim Kennedy
Great idea if the caliper is off the rotor -- I retract my pads before I remove the caliper -- use a large [approx. 10" opening] c-clamp -- works everytime.
03protege
Louisiana
I don't understand, the caliper is still on the rotor I just undid 1 of 2 bolts to pivot it.
Or are you able to remove your pads without even doing that?
03protege
Louisiana
Well I didn't want to spend too much money on this, if I was going to buy one of these nice caulk guns to chop up I might as well just buy the tool :lol_hitti
I figure everyone has at least 1 old unused caulk gun laying around.
buening
Decatur, IL
This depends on the caliper type. A floating single or dual piston yes, but a four or six piston you have to remove the caliper in order to retract the pistons since it isn't a floating design but rather a monoblock.
03protege, this is one of those "why didn't I think of that" moments for me! Good work.
4BT
:spit:
That's great
The cheaper guns tend to flex too much.
kkroger
I have used, when I was a working mechanic, my Channellock 20" I think 480 pliers.... Works fine and easier etc etc....
No time for Unitaskers....
