Bondo,
There is nothing that makes me think the system is using any make up water.
Yes, there is a check valve installed.
I guess what I'm trying to get at is this:
Is it all right to run a hydronic heat system with no available make up supply when you may not be on location for up to a month in the heating season?
Want to do what I can to keep system running and in event of a fail, keep water damage to a minimum.
Cold up your way, what type heating system you running?
I've run by your location a number of times crossing lake Ontario- running boats up to Clayton from NJ. Nice area.
Skiff
Ayuh,.... If yer heatin' system is sealed, as it should be,....
It'll run, all by itself,
Forever, or til there's a leak,....
If yer a Creative Engineer, such as myself, My 1st thought of a safety system to back up yer lack of available refill antifreeze,....
You could build a tank, of whatever size ya believe to be necessary, with a screw(tight air seal) on cap on the top, with a schrader valve on the cap or tank,....
From the bottom of the tank, a hose or line to the pressure regulator/ make-up water valve of the boiler system,....
Fill the tank with antifreeze, 'bout 1/2 to 3/4ers full(leavin' head-space for the air pressure),...
Screw the cap on, tight, 'n pressurize the tank with air, say 60 or 80 psi,.....
If there was a leak, the reserve antifreeze would be pushed into the system to the set value, til the antifreeze ran out, or the air pressure equalized with the system,.....
As far as an Alarm, if it monitors the pressure of the boiler, that's
All ya need,....
Flow is irrelevant,....
If the system is set-up for a 12 psi minimum, a sensor for any value below the 12 psi, will tell ya,
ya got a leak,.....
Ayuh,... It does get pretty damn Cold up here,....
Already seen -35*/ -40* this year,...
I'm sittin' here in my river house rental, that I designed, 'n built the in-floor radiant heatin' system for,...
Bein' it's always been a rental til now, is Why it's antifreeze filled, rather than water,...
Startin' this year, We're livin' in this house for the winter, 'n will move next door for the summer, rentin' this house,...
Previously, for winters, I had a company house with baseboard hot water heat, which I designed, 'n built an outdoor wood boiler, which I tied directly into the house's hydronic heatin' system,....
Burnt free wood for over 10 years, I got from a local arborist I barter with,...
Frank was pretty upset I quit heatin' with wood, as the value of Me bein' a phone call away, I guess, means an awful lot to 'im,....
For now, I've got a Harley Sportster sittin' in his garage, that is mine to use whenever I want, so long as I answer the phone, whenever Frank calls,....
Drawback to that is,... If it's nice enough to go bikin', I'd rather be out Boatin',...
Which is the same reason I don't own a Harley of my own,...
Anyways,......
I'm right here at the head end of Chaumont Bay, 100 yards up-stream of the state bridge over the Chaumont River, in the village of Chaumont,....
If yer ever up this way, with some extra time to kill,....
I've got dockage, so long as ya can clear the bridge which is Usually, 'bout 13'6" above the water,.....
Yerself, or any other friends are Welcome to stop by, 'n chat for awhile,....
Tie up over night if ya wish,.....
Just look for the 34' Nauti-line houseboat moored out front,.......
