I came across a transmission cooler that measures 7 inches by 12 inches and is rated to 150PSI.
The only issue is the diameter of the tubing is only 3/8th of an inch, I currently have a 1/2 inch tube connecting my pump to the check valve on the tank. Will I be hurting my CFM and tank fill times by downgrading to a 3/8th inch tube over 1/2 inch?
