sdowney717
- Joined
- Mar 17, 2010
- Messages
- 964
I suppose using the tree trimmer trick is better?
I suppose using the tree trimmer trick is better?the pole fuses i see in that link are on the line side.
are there fuses on the load side as well protecting the transformer itself?
For most residential type transformers you are looking at a 3-5amp fuse.
Tom
You probably meant to say a 30-50 Amp fuse link. I've never seen a 3 or 5 Amp fuse link, and I've changed alot of them out over the years. It's just a piece of stranded copper wire. So a 30 Amp fuse link would be about the size of a piece of #10 AWG wire.
....The poco came out and swapped my meter for a new 200amp unit, but refuses to help me with the connection from their overhead service cable to my new 4/0 cable from the new weatherhead. They won't even come out and turn off the power upstream so I can make that connection myself....
Yeah I know.... I'm completely taken back that they seem to have no regard for safety.... they're the power company! I plan on getting my inspector involved. I think he may have some weight with them to get things done...
This is Detroit Edison (DTE) by the way...
yes, look at the birds sitting on the wires, some of those wires are uninsulated carrying voltage.if you understand electricity and there isn't any path to ground or current flowing through you are fine
cowboyjosh funny you replaced a panel in Hilands Ranch. My parents lived in a subdivision a few miles. The people that bought their house wanted the FPE panel replaced before they closed. The electrician that replaced the panel said the same thing about XCEL being a PITA. The builders in the 1980s in that area all seem to have used FPE panels, I remember as a kid when the fire trucks came racing into the subdivision to put out a panel fire. It took 5 big fire extinguishers before Public Service CO got there to kill the power.
We haven't heard from the OP since 8/14...Hmmmm
