Making a Outdoor J Box Weatherproof
mobiledynamics
Gotham City
I had a pro-electrician do a exterior run for our Hvac.
Regular Bell Box used a J Box to transition from interior to exterior.
Noticed that one of the cover screws was rusty.
Removed the cover and found water inside it.
I ended up proceeding to make weep holes on the bottom of this box.
Also replaced his regular wirenuts with the ones filled with the silicone.
Also removed the regular cheap gasket they provide with these boxes, and bought a piece of silicone sheet and made a better gasket between cover and box.
Need some ideas or suggestions on resolving this
- Any idea on to drill out a screw that is sheared off inside one of the screw mount holes in the cast alum box. I don't think a regular drill and retap will work.
-Suggestion on further alternative means on weatherproofing this box. I suspect water may also be coming in from either the hub fitting or the other 2 screw covers ontop of this box.
-The run from this box is PVC so it's not a easy fix on redoinng the hub connection unless I cut it, and the use a coupler..
Mustang51js
Haskell nj
Silicone around box and where wire comes into box. Most of the time water gets in from the cover so if you put a better weather seal you should be good. Haven't found a way to get the broken screws out yet either.
alfredeneuman
Fullerton, CA
As an alternate to removing the broken screw,
There are 6 or more 6-32 tapped holes meant for covers in a Bell box.
They're on both sides of the 2 you would normally use.
RECox286
South Joisey (yeah, that is part of the USA)
Throw the pot metal box away (as far as you can toss it)
and look for a PVC box with the features that you need for
the installation. You can get wx proof entrance connectors
that will actually keep water out. Your idea of replacing the
cover gasket is a good move, as well as using silicone filled
wire nuts. When you tuck the wire nuts, insure that the
wire nut is in the wire-down position so that any condensation
running down the wire will not end up in the nut. I have a
devil of a time with electric construction here on the Island
in central NJ. Most electricians keep the few of us that take
pains to keep things dry, busier than a hive of one armed wall
paper hangers. We have a terrible time with wx proofing and
that doesn't mean just on the outside-in-the-wx stuff. The
humidity, salt and air infiltration makes it a really 'fun time'
vocation. Then Sandy comes along... Still digging out !
Uncle Bob
