Making BBQ parts
scooby074
Nova Scotia
The BBQ was going to give me Tetanus. So in the spirit of GJ I decided I should make some new BBQ grills. Constructed of 3/8 roundbar , 304 SS. Mig welded.
Ole rusty. Notice the flaking. I framed it in angle to use as a template. This was a mistake, see below.
Raw Materials. 3/8 SS round, spaced 3/8 apart. The grill required about 34 pieces, 48' total. Original plan was to eliminate the center split, so it would be one continious grill. Bad idea.
I didnt have 100% argon, so I used C25 and 308ss wire. There is a bit of weld staining as a result. My first time welding a "large" SS project. I have lots of experience welding mild steel, been doing it for years, but this Stainless moved around like a wet noodle. I limited my heat input, kept the welds small, cooled the material between welds, only welding 3 slats at a time, and it still warped. I might have had the jig frame too constraining for how much the metal moved, but it ended up a bit of a mess. I had to cut the grill into 2 pieces to reduce some of the tension and get it to lay flat. I know for when I make my stainless BBQ, Ill either tig it or figure out some way to deal with expansion. A good learning experience.
Finished product. The BBQ didnt care about stained welds :) and the steaks came out great, without any rust flakes !!
scooby074
Nova Scotia
nice looking grills. hate to think what the stock cost you!
Thanks
Stock wasnt that bad. I was quoted $1.80/ft but when it came, it was $2.00. Metal prices are so variable right now. Its a Broil King, the replacement grates are around $150, and they arent as thick as what I made. I think I came out ahead. Plus it was a trial run for making my own Stainless "Lifetime" BBQ down the road.
Speaking of stock prices, I also had to buy some 1.5" SS angle.. $9.50/ft. That one hurt!
larry4406
Northern Virginia
Nice job on the grates!
I did mine differently. I used 1x1" square stock to hold the rods. The holes in the square stock allow the rods to float. Only the end rods were tacked to the square stock. I used regular carbon steel. I was concerned over warpage.
scooby074
Nova Scotia
floating the rods is a good idea.
Warpage was much more of a factor than I considered before starting. Im not sure how the OEMs are making welded grills that don't warp.
Napoleon has the "Wavy" style grill that Im sure helps to control warp, but that would require some sort of a die to bend the grill segments into that unique shape, not really doable for the home shop.
matt_i
You could bend the wavy rod with a matching set of hard maple dies in a typical H frame press and file/carve/rout a guide to hold the rod from spitting out the side. Some trial and error for springback if you're trying to hit a dimension but those are pretty gentle bends.
whateg01
doo dah, kansas, usa
Stainless is going to move on you, even tig welded. Welding little bits like you did might have made it worse because one section cools to it's final shape then the next section cools and pulls the previous bit.
lilredex
Toronto
We had the same issue in our well used Broil King. Was lucky enough to find some heavy cast iron grilles from a junker at the curb that fit nearly perfectly.....solved that problem. Am also in the process of making up a flat top for it.
A neighbour built a free standing brick BBQ and gave me a bunch of reinforcing rod to make a grille for it. That worked out really well, for many years.
scooby074
Nova Scotia
That
That grill on the left of the first pic is an interesting design.
Feel free to update this thread with your flat top progress if you want. Might be a good idea to put all these BBQ mods and ideas in one place? I know I gave a quick look before I started and didnt find much, just one thread that I cant seem to find anymore..
scooby074
Nova Scotia
I wasnt sure if keeping it cool or letting it heat was the best course. I was more concerned about it ending up the exact size because the grill kind of sits down inside a lip with a tight fit.
In hindsight I would probably not fit the jig so tight and make the grill undersize. Then make mounts in the BBQ to fit if the new grill was too undersize to work with the existing mounts (recess).
Like I mentioned, this was a learning experience for working with stainless. Up till this point, my stainless experience other than a bit in trade school, was some exhaust repairs.
lilredex
Toronto
That
That grille is ribbed on one side and flat on the other, kind of different.
This is what got me going on the flat top project:
Good idea to keep BBQ repair ideas here.
scooby074
Nova Scotia
I like the flat top idea. Ive been thinking about it for a while. Usually im cooking a lot of hamburgers and hotdogs (kids!) so it would be handy. I was thinking about making an insert to cover 1/2 the grill, so I could have flat top on one side, bbq grates on the other..
AVE made a video a year or 4! (time flies, memory ***** lol) ago about making a flattop. His was pretty massive, but got me thinking. He ended up re-doing it to address some problems.
cpttuna
napoleon ohio
Thanks
try the scrap yard and recycling center. this is where I usually get my ss
scooby074
Nova Scotia
Oh yeah. I do check the scrap yards, but most time there is nothing but small pieces and type is a bit unknown other than "its stainless".
Sometimes clean uniform stock of a known type is worth the cost. Food was going to be cooked on this so some random SS material out of some random chemical plant locally wouldnt be really confidence inspiring either.
cpttuna
napoleon ohio
if you are fortunate enough to have a recycle place or scrap yard near you that has stainless, you sometimes can get good ss scrap cheap. My best buy was 1" round stainless 12' long for $7.00. It is all about timing. If I see something like this 1" round deal, I jump on it. Did I need the 1" round at the time? No, but I was sure it would be gone real soon.
Walkers
Cave Creek Az
Nice work. I have made a few for people on my plasma table. I can put it a grate design and throw in their name, or initials. If I put them in backwards they can wear their name onto the steak.
