Part 1
A couple days ago I was driving home with the radio on when all of a sudden I noticed a burning smell. Not the smell of oil burning, or wood, but the unmistakable smell of an electrical fire. Luckily, I was only a couple miles out of town, so after turning off everything electrical that I could, I made haste for the fire department, just in case.
Once there, I checked out the electrical, using my nose to search for the problem. It wasn't long before I discovered the problem was the radio itself. Bummer, it's not a cheap unit and while it came with the car I kinda like it.
Yesterday evening I decided to get down to business and fix it. The first order of business was to get the radio out of the car. I've never removed one. Looking at the directions that were in the box left in the trunk, I discovered that I need a special "key" to release the latches on the radio rack. Studying the radio the previous owner removed to install this one, I made up a couple of keys.
First, I sheared off a strip of .032" Brass 1/4" wide:
Then I cut it into sections 5" long:
In a bench vise, I bent the last 3/4" of the strip over at a 90-degree angle:
Finished result:
Here is one of them in use:
Success!
Here's what came out from behind the radio. If you look closely, several wire ends are covered in electrical tape. That's my doing, the bare cut ends of several wires were exposed when I pulled the radio. If I did this kind of a wiring job as an aircraft mechanic I'd be fired on the spot!
Finished result:
Success!
