FarmerSid
Hey all! Wanted to run something by you all and get some opinions. I'm thinking of buying new control arm bushings, removing the steel insert, drilling the polyurethane out to the OD of a new larger steel insert and inserting the new steel insert inside the polyurethane bushing.
Are these steel inserts hardened?
The factory bolts bolts are metric and a 10.9 hardness. I'm under the impression that either the bolt or bushing needs to be hardened but not both. Am I correct in that thinking?
The purpose of this is to increase the bolt size that holds the control arm on from 12mm to 16mm.
