Makita 1/4 impact driver
JonnyMac
Victoria, Australia
Im in the market for one .. but apart from brush vs brushless does anyone know what the differences are between the 4 or 5 models which look identical are? I mean they are all 18v power so it cant be a huge difference can they?
My local power tool store is staffed by 12 year olds who really have no clue!! And ill be buying on line..
cheers guys...
BreeStephany
Oregon
I have the older discountinued Makita LXT (green & black body) impact driver with the large capacity batteries and the Makita (white & black body) impact driver with the smaller batteries.
I bought the smaller white impact because I needed an impact for a quick job out of town and didn't have my older Makita.
The MAJOR difference I can tell is the difference between batteries. I can generally get 3~4 times the driving time off the larger batteries compared to the smaller ones. Outside of that, I have driven 1/4" x 12" timbertech lags without predrilling and neither impact bogged down until the battery was dying. Grabbed another battery and went on.
When I was working as an electrician, I had a coworker that had the complete LXT set. He was terrible about leaving his batteries in the truck at night and his batteries wouldn't hold a charge after about 2 years...
I have used mine almost EVERY day for the past 7 years and they are still running strong, but I have NEVER let them get cold unless I am using them. Having them out in the cold while your on the job is fine because they actually will maintain a safe internal temp (as I understand it) until they no longer have a charge.
I also charged my batteries every night while using them. When I stored them long term, I drained them to about half capacity and left them and then charged them about once every month or so and then would drain them back down a bit.
I find the Makitas to be pretty bulletproof. About 6 months after I got my first impact, I dropped it 20' out of a scissor lift. My first thought was that I had destroyed it, but after getting down off the lift, I found that it dropped directly on the bit holder extension I had on it, which bent the hell out of the holder and took the brunt of the force, leaving it completely undamaged outside of a few scratches on the rubber and plastic, as well as a few scratches on the battery.
BreeStephany
Oregon
Whats left of the bit. I keep it laying around as a talking point about how bulletproof the Makitas really are.
Filson
NE WA
JonnyMac - The White and black ones are designed to be more compact and lightweight. The black and green ones have larger batteries and from my own experience, built more 'heavy-duty' than the white and black (not saying they are weak or anything).
The differences past that, are the options on brush or brushless, what type of charger they come with, and a few other options. Ignore the 12 year old guys at your local retailer and spend some time on Makita's site.
I have the LXDT04A (http://www.makitatools.com/en-us/Modules/Tools/ToolDetails.aspx?Name=LXDT04A), and use it very frequently. I've had it for about a year and a half now and have absolutely zero complaints, and nothing but praises. The power is insane, it's very comfortable in the hands. The balance is superb and the batteries will charge faster than you drain them.
If I were to ever lose mine somehow, I wouldn't even start to do any comparison shopping, I would simply order another one without pause.
Good luck!
cyato
Orange County, CA
Here's a couple different reviews on Toolguyd for the different models...
http://toolguyd.com/makita-cordless-18v-lxt-impact-driver-lxdt01/
http://toolguyd.com/makita-lxdt06-brushless-impact-driver/
http://toolguyd.com/makita-brushless-hammer-drill-impact-driver-rotary-hammer/
I personally have the original blue/green Li-Ion impact from 2004 and the LXDT08 brushless. Both work great. The brushless is not as nice and smooth as the older one. The 01 and 06 have features that make them more controllable.
Filson
NE WA
Cyato - I went with the brushed version myself too. When shopping at a specialty shop, the guy asked what I'd be using it for (building custom firetrucks at the time) and he recommended I stay away from brushless. They have their perks, but for heavy use, they don't have the durability (at least not yet) compared to the older brush style.
J
JonnyMac
Victoria, Australia
I was actually talkng about just the tool only. I have a stack of 3AH batteries.
Here are the various model numbers of the green, non brushless, tool only options! !
Btd140z
Dtd146z
btd142z
btp140z
btp140rfe
