Makita Addiction Thread
KnurledNut
n/a
It seems that Makita is unable to consistently make a profit in North America, despite frequent price increases.
Speaking for myself, I feel like XGT bit them in the ****.
They would have more of my money if they put that effort into the LXT line. Higher capacity batteries. New tools.
A lot of people are heavily invested and dont want to switch to XGT.
Sell what we want and you will turn a profit.
jollygreengiant
Ontario, Canada
I've wondered this as well. IMO the smart play would have been to continue investing in the LXT line while developing a 60V line for future release. But then I have no XGT tools either so I can't really comment on them.
FTWingRiders
Central Ma
If Makita offered a higher aH battery, maybe 8 or 10aH I'd probably pick up a bigger 36v saw. For now I'll stick to gas for the big boys.
I'm still continuously impressed by this little thing though. Using it on the trees just for fun.
It’s true… I’ve got the 36v and it just sits the shelf.. not the power I expected. This little 10”, however is great for cleaning up the smaller stuff.
shibertus
Are they made in Japan?
Is there any Makita brushless tool for US market which is made in Japan?
Thanks.
The impact is made in Japan and was purchased from Dogu Tool. The owner of the site lives in Japan and sells Japanese domestic market tools worldwide. All the Makita tools he sells are made in Japan. Prices seem to have gone up since I got mine, but the service was excellent and I will probably buy more from him in the future. The drill was purchased in the US at Home Depot and is made in China.
txhousa
So all Makita tools for US market are made in China?
Dave455
Sussex, England
Has anyone tried the Makita 18v heat gun? I want it just for heat shrink on wiring:
In Europe this is the DHG181, not sure about the USA model no.
I’ll be interested to hear as well.
This question (heat shrink) came up on another thread.
I have a friend who uses a Weller Pyropen. This is basically a gas soldering iron, but comes with a nozzle for heat shrink. It’s an incredibly useful tool and I’d like one!
Somebody else advised the Iroda MJ-950. It’s certainly less costly, but I can’t vouch for how it works.
A couple of readers expressed the view that the 18V cordless heat guns were a bit puny. I can certainly see how this might be the case, and I can’t see myself using one for paint stripping, but heat shrinking is a pretty undemanding task.
The_Inspector
The Netherlands
That Weller is quite expensive and it is very limited in use. The Makita is more versatile I think, the different nozzles give it more flexibility. In Europe these can be bought for around $140, Btw Dremel also has something similar, don't know how it performs though.
Dave455
Sussex, England
The Weller is basically a soldering iron - and that feature in itself is useful (or at least it is for me) but I find heat guns incredibly useful as well, so I’d be interested in one if they are reasonably effective!
With a lot of tools (especially Makita) I often know someone who has one, but I can’t find many folks with first hand experience of these.
Etchase
Hawaii
I have a small compressor, so an air die grinder is out. What are your thoughts on this corded model? There are newer ones, and smaller ones. I want to mostly grind steel, rust, welds…on a variety of gnarly equipment, but might want to finish something to presentable appearance.
Makita GD0800C 1/4" SJS™ Die Grinder, Teal https://www.amazon.com/dp/B000056NOU/?tag=atomicindus08-20
Snapped-off
Indiana
Glad to see some new posts here. We must not have too many problems.
Late post of my father's day present. XCU03. Used it to cut some logs as a test.
Found out I need to go easy to prevent staling the chain. If you do, you have to power it down and then back up. Is that normal?
Yeah or give it a few to go green again. If you go hard on cutting it'll shut itself off and you gotta give it a cool down of about 30 seconds.
Great for limbing in my opinion. Can't give up gas on bigger saws yet.
engineer2
Chicago burbs
Yeah, the batteries where pretty hot after cutting a log lengthwise. No problem. Finally I have more batteries than tools.
The_Inspector
The Netherlands
I got quit a few Makita tools and some Mboxes. the plastic moulds they come with are not the most economic in terms of space (and durability). How and from what material did you guys made your layout/inserts? I Got some ideas already from the Festool forum, but always looking for more solutions. It seems like wood is the cheapest option, but am also looking at PVC sheets and glue those and maybe cover it with EVA foam.
f121
UK
As a follow up to this, I read a bunch of reviews on the Makita 18v LXT heat gun, which said that it didnt get properly hot, so decided against it.
I have used a butane soldering iron for both heat shrink and soldering, currently a PortaSol 125, which is kinda the UK standard for butane soldering because it was available rebranded from Snap On until recently. Its good as a single tool in the field, but using it for any kind of bench work or significant wiring is a pita because my workflow is do a solder joint, heat shrink it, repeat, which would mean constantly changing the tip on the torch (When its too hot to touch) risking damage to the catalyst etc. I keep a butane cigarette lighter in the box of my portasol for doing heatshrink beacuse its less hassle than reconfiguring the torch.
I eventually settled on a Dewalt XR heat gun with a makita battery adapter, it gets plenty hot enough for heat shrink, plus it was 2/3 the price of the makita heat gun!
Dave455
Sussex, England
Great feedback!
Thanks.
Trapps
The Detroit Zoo
My first Makita tool:
I am firmly in the Bosch cordless environment, but their range is less than half of Red, Yellow and Teal. Yellow was out for me based on previous personal experience. I spent a fair bit of time looking at Red and Teal and decided I generally liked Makita better. Fit, finish, feel, sound all seemed half a click better, in my opinion, than Red. I've used both in a work setting and feel performance is a wash - both having stars and average players in different categories.
I imagine there will be more Makita tools in my shop now that I've embraced their battery platform.
BigLeagueSmoes
Central IL
Welcome to the Makita gang :rocker:
nadogail
Coronado, CA
My first cordless drill was a Makita with the 9.6 long battery. When it died my employer gave me a yellow drill, after it died I bought a Royobi kit and the batteries were not to my satisfaction, so i bought a pair of new Batteries; I should have not bought the Royobi and just bought the more expensive Makita. I now have a great Makita and it has been excellent for the last few years.
BigLeagueSmoes
Central IL
Makita TM52DZ (Japan Market) Brushless 18V Oscillating Tool Review:
I'll keep this relatively brief, just want to share a couple first impressions and honest opinions with you all. Bought this oscillating tool for use around home and for a small side job I have coming up that will require some plunge cuts on deck boards. I opted to buy the Japan market one simply because it was slightly cheaper than the U.S. version ($249 U.S. at Home Depot vs. $224 Japan from eBay international authorized seller) and it comes with a nice hard case for storage and it came with: sanding pad, 2 60 grit, 2 120 grit, 2 240 grit, wood/metal blade. The color is the only real difference that I notice; U.S. version is all black like their subcompact line and the Japanese version is standard teal. They are both made in China which I'm not too thrilled about but it is what it is. You can read about all of the features on any retail website and there are a few good video reviews on youtube too that are worth a watch.
Performance thoughts:
  • Excellent precision cutting control, better than anything I've used (including Milwaukee and Dewalt)
  • NOT the fastest cutting tool (Milwaukee is faster) which may also be a little blade dependent but it is still very good and doesn't leave anything to be desired in my opinion
  • Doesn't bog down, plenty of guts to it
Ergonomic thoughts:
  • By far the quietest oscillating tool I have ever been around, it's SUPER quiet
  • Virtually zero vibration in the handle, easy to use for long durations
  • High quality rubber grips and protection around the head of the tool, keeps you form marring work surfaces
  • NOT the smallest/narrowest tool, pretty bulky head
  • Light function is decent but not amazing
  • Starlock/plus/max blades only just keep that in mind
  • Blade release lever is simple, quick to change, no other tools required which I like. Release lever is very stiff, may be too stiff for some people to release easily.
In my opinion: buy this tool if you're already in the makita battery platform, if you want a comfortable and precise cutting tool, or simply if you want a well rounded quality tool that will last you years. Do NOT buy this tool if you need something super compact in size or if you don't want to buy Starlock blades.
7D445A25-A30E-4AC4-91FB-BEC59E29983D.jpeg 0735D54D-3059-4893-8E3B-FB02351962AB.jpegE1E830C9-00D7-4F77-AAFD-1ABA540468BB.jpeg 412CAE35-7E7F-461C-9F4A-9B1A04530D02.jpegED77427B-7F20-48E7-8352-D035E31FDFA9.jpeg A6AD0A76-9B87-4303-8926-7230F22BCF8B.jpeg3CFECAA8-3866-4EE3-B7E2-8211FCE48357.jpeg 70003FC4-B5A4-41CA-AB1F-29D8A70C9BC0.png67FF6C96-8265-4390-9C8C-B79F2E968278.jpeg 8F7AB81E-C606-433D-A74A-B5B061C095EE.jpeg
Ton ton
Page County,VA
Ergonomic thoughts:
It looks like a handy tool to use.
jollygreengiant
Ontario, Canada
That's one thing I hate about my current multi tool, how loud the thing is. If you say that new one is a lot quieter, well dang it now I'm really tempted to go look at one. Is there any difference in the Japanese vs north American ones besides the colour?
I hear what your saying about the country of origin but I've learned it really depends on the company. China is certainly known for producing enough cheap ****, but if the company has a good focus on quality they can make a decent product over there. Makita seems to be one of those companies, they pretty well have to be in china for competitive reasons but they keep a tight control on quality. I'd certainly prefer a Japanese or north American built tool, but I'm not afraid of a Chinese built Makita.
Dave455
Sussex, England
Noise seems to be an issue with most of these multi tools. I went with Fein as it’s better than many, but I’d like a cordless too.
With regard to the whole “country of origin” debate, it’s incredibly varied with Makita, certainly here in the U.K.
Makita make, often many, different grades of tool. I have two Makita angle grinders. The cheapest is made in Romania, and it’s perfectly acceptable. My best is made in Japan, and it’s superb. I have drills and an impact driver also made in Japan, and they are also superb.
I don’t particularly like the made in China Makita either, but it’s better than many Chinese power tools.
It seems to me, reading the comments on this forum, that the U.S. gets a lot more “made in China” Makita than I see in the U.K. so maybe sourcing products from another market is a sensible option.
mrvm
PA
How much for the XML08? Our store only carries the basic plastic model for list price.
Of course I can order an XML08 for $900.
I didn’t post my deal because it’s probably not repeatable but ymmv. The deal was definitely worth it for just the batteries ;) with a mower thrown in.
mrvm
PA
Massive suckage. Was it getting clearanced?
The manager had two new-in-box marked down. He said he asked several contractors at the pro desk whether anyone needed more Makita batteries. I was just in the right store at the right time. Xmas displays were prepped for display in the same area.
