Makita Addiction Thread
smitty9999
Toronto
I've been eyeballing that one for a portable unit, but at 88#s I'm a little wary. Do you move it around a lot, or is it stationary? Looks kinda.. bulky.. I wish it was more compact.
I keep it stationary, however, it rolls very well when it does need to be moved.
I keep it in the garage but I have brought it into my house. It folds up easily and can be carried.
All
I also have a Makita MAC 5200 Big Bore.
Moving it is very easy. The fold down handle makes it compact.
Lifting in and out of a truck could be a struggle for smaller people.
The dolly arrangement of the 5200 makes it easier to add a secondary air tank when needed. For example, I set a Hitachi ASME code welded air tank right on top of the tool tray of the MAC 5200.
The extra tank reduces cycle time, and allows more moisture to drop out of the air stream as the air rexpands into a large secondary chamber prior to tool delivery.
engineer2
Chicago burbs
What Makita tools are you guys getting for Xmas?
I'm tempted by the 2 extra battery deal: Four 6AHr batteries and dual charger plus the 14" chainsaw for around $375. I wouldn't use the chainsaw but a few times each year, but it's like paying an extra $100 to get it.
it's either that or their beastly 1/2" impact.
KnurledNut
n/a
Isnt it the 5ah?
Com_VC
Australia
Is that the one with the removable sleeves so it become a vest? Thinking of getting one some day.
KnurledNut
n/a
Anyone using the new makita 18v heated jacket? I can’t find much info on it.
I have the one Com mentioned. I find it too nice for hard, heavy work.
I use it for less vigorous applications, usually as a vest more than a coat.
It does its intended job fairly well, but dont expect wood stove heat.
Interestingly, two of my dislikes were addressed in the second generation:
1. The battery compartment was revised for the better, looks and function.
2. They added heat zones for the front pockets which was sorely needed.
You’ll want a close fit to benefit from the heat most effectively.
oflannabhra
KY
I picked up the Makita XLC02RB1W vacuum kit for $80 on Amazon this weekend. It's not the upgraded brushless version, but at that price it is hard to argue.
I'm excited about the 2.0Ah battery and charger, especially. We need a vacuum for inside the house, and I prefer the 2.0Ah batteries in my drills, so I'll probably be swapping out my 3.0 battery for it.
QwikKotaTx
Seabrook, TX
That price for the vacuum is a steal. I bet my wife paid nearly double that for mine. I am a penny pincher unlike her. I sent her the link when it was on a temporary sale for $99. I mainly use it for our vehicles but I have used the floor attachment a few times in the house. It would make a great apartment or dorm vac.
I am waiting for old, loud Crapsman compressor to die so I can get a Mac and plumb it to the 20 gal tank on the Crapsman. I would think that would reduce the duty cycle on the Makita when using an air tool.
Sent from my VS987 using Tapatalk
TLCObsession
Bellingham, WA
I bought the track saw and got the bonus 2 pack of 5.0 batteries (4 total) and the 39" track. I added 2 of the 55" tracks and 2 sets of the joining hardware.
Eric29
Western NY
My son was thinking of buying a tablesaw because he was putting in a lot of hardwood flooring in his house. I lent him that very tracksaw and he loves it. He’s using thick flooring and the tongue and groove clamps the flooring together so that the tracks can sit on top of them and he can cut the flooring at any kind of an angle even if they’re small pieces.
dylanmitchell
Southern California
How is the Makita AC001 for inflating tires to 35-40 psi and occasionally a 70 psi tire and general home and shop use with a tire and blower (no air tools other than blow gun and tire chuck)? Looking for a portable single-stage reciprocating compressor for inflating tires, cleaning up messes, blowing the water out of mirrors, doors, etc. after washing car, and things like that. Know oil-filled are quieter and more durable but want to avoid having to change oil and belt-driven can be less portable and cost more.
Makita AC001
SCFM @ 40PSI 0.6
0.4 SCFM @ 90PSI
MAC 700
SCFM @ 40PSI 3.8
SCFM @ 90PSI 3.3
Dewalt pancake DWFP55126
SCFM @ 40PSI 3.7
SCFM @ 90PSI 2.6
bixxjs
United Kingdom
The Die grinder is over 25 years old, on its second rebuild and still going strong.
engineer2
Chicago burbs
I've had the teal/black version for an few years now. Great for picking up dust, crumbs and pet hair. Pretty useless on carpets and picking up random leaves that come in on shoes. The 2 Amp hr battery is just enough to go over most of the hardwood floors in the house.
dylanmitchell
Southern California
Unpacked the new MAC700 air compressor, added oil, installed the air filter, and ran for the 20 minute in with the drain valve open. Happy with it so far and expect it to be a competent small compressor. It's solid and looks well constructed. It's quieter than friends MAC5200 and about the same level as our shop vac. Got it for blow cleaning and tire inflation no plans for air tools or paint spraying.
It's compact and not the worst thing to move around at 50 pounds. May look at getting a dolly to mount the compressor and air hoses on and making it easier to move around. I would prefer having the quick coupler face forward vs to the left side and looks like a slightly larger tank would fit while staying within the proportions of the motor and cover but it shouldn't have any problem topping off tires, blow cleaning, and auto detailing.
Considered the MAC 2400 and but at 77 pounds and never liked the MAC 5200 a friend has good output but it's very loud and quite a bit larger though it puts out a lot more air.
2 HP 4-pole motor produces 3.3 CFM at 90 psi
oflannabhra
KY
Can anyone help me figure out the differences between Makita's impact drivers and drills?
I've currently got the XDT13Z (from a kit), and I saw a deal on the XDT14R. It looks like the XDT14R has selectable modes.
I've currently got the XPH12Z (also kit), and the same deal has a XPH07Z. My XPH12Z did not come with a grip or depth gauge, whereas the XPH07Z does.
It seems like maybe these are upgrades from my current tools?
Eric29
Western NY
I don’t see any real world difference. My Makita tools are even older and they work fine. I just had to file the tabs off of them so they would take the newer batteries. i’m not sure what kind of work you do but the tools you now own will probably do just as well as the newer ones.
Fireguy116
My house
I’m wondering if makita is really going to leave us hanging on the 18v side and not release either bigger batteries or at least up grade the current ones to 21700 cells. Would make sense to make a new 3 and 6 with those cells. I just see with the new 40v coming out and the new hammer drill and batteries in that line the 18v will eventually get forgotten about unless they up date the batteries. This is my only complaint with makita. Like come! Hey Makita U.S.A. if you’re listening or checking the board, give us what we want bigger or at least H.O batteries.
oflannabhra
KY
I looked it up on Makita's site, once I found their comparison feature. Both are pretty big upgrades, but here's the "tale of the tape":
XDT14Z (delta to XDT13Z)
torque: 1,550 in/lbs (+50)
weight: 2.9 lbs (-0.4 lbs)
length: 4.625" (-.375")
max RPM: 3600 (+200)
max IPM: 3800 (+200)
modes: 3 (+3)
So, the XDT13Z is a marginal upgrade, offering more power in a smaller, lighter package. It also offers different torque modes, whereas the XDT12Z is just trigger-driven.
XPH07Z (delta to XPH12Z)
torque: 1090 in/lbs (+560)
max RPM: 2100 (+100)
length: 8.125" (+1.375")
weight: 5.8 lbs (+1.9)
BPM: 31500 (+500)
XPH07 is flagship hammer drill and includes an all-metal chuck, gearbox, and clutch. It has top in class torque, and even though it is heavier (due to more metal), it is top of the line.
I found a deal for both, with 4 x 5.0Ah batteries and charger for $280, so I'm sticking with 'em.
dylanmitchell
Southern California
What air compressor are you running? Like the MAC700, MAC2400, and MAC5200. The AC001 is too small and the high pressure isn't a good general use compressor.
I went with the MAC700 since I'll be moving it by myself most of the time and using it for inflation and blow cleaning but no air tools.
Mac700 2.0 HP Big Bore (1.7 running HP) 2.6 gal.
RPM 1,730
80 dB
(40 PSI) : 3.8 CFM
(90 PSI) : 3.3 CFM
Max: 130 PSI
52 pounds
4-Pole brushless motor draws 12.3 amps
18" D x 22" H x 10" W
Really like the MAC2400 but it's a little heavy for portability
MAC2400 2.5 HP Big Bore (2.1 running HP) 4.2 gal (dual stack tanks)
RPM 1,730
79dB
(40 PSI) : 4.8 CFM
(90 PSI) : 4.2 CFM
Max: 130 PSI
77 lbs.
19.5" D x 18" H x 18.75" W
A friend has the MAC5200 and it puts our some serious volume but is loud. Noise may be from running at a higher RPM and increasing power.
MAC5200 3.0 HP (2.1 running HP) Big Bore 4.2 gal.
3420 RPM
90dBA
(40 PSI) : 6.9 CFM
(90 PSI) : 6.5 CFM
Maximum Pressure : 140 PSI
88 lbs.
4-Pole brushless motor draws 13.8 amps
29" D x 19.5" H x 19" W
For perspective and what I'd buy if I needed something more capable than the MAC 5200.
FS-Curtis 20 Gal. 2 HP Garage Mate
? RPM
83dBA
(40 PSI) : 5.5 CFM
(90 PSI) : 5.5 CFM
Maximum Pressure : 135 PSI
148 lbs.
41" D x 31" H x 19" W
Com_VC
Australia
Well that's a start, wish they put the charger in a more accessible location, say at the top of the unit. Ah well, maybe the next release :)
Fireguy116
My house
Let’s just hope the information is true that they told me when I called customer service the other day. They told me a 9.0 ah battery is in the works they just didn’t have a release date they could share. But they said they are definitely coming out with a bigger battery soon. Again that was according to makita USA customer service.
dylanmitchell
Southern California
Makita's fit and finish is so nice I wish they were more on top of battery tech and had more products. I've built up a set of Milwaukee M18 tools and batteries but they just don't have the feel of quality Makita does. For corded I can still go Makita but they need a wider selection of battery tools before I can commit to their system.
gmwelder86
Oakdale , ca
What don’t they have your looking for. Look thru their entire catalog not much that isn’t covered.
Com_VC
Australia
I'm thinking they probably should bring out a Cordless Magnetic Drill and Cordless Hydraulic pump as well seeing these are tools commonly used in industry.
American Locomotive
Rhode Island
Makita claims there are 200+ tools that utilize the 18v LXT batteries. What battery tools do you need?
Farmer888
Ontario canada
Have a mac2400 compressor here, been awesome for the year I've owned it. Use it for tires and blowing equipment off etc. Love how quiet it is! Did some limited air impact work in the field with it but it's not enough to be productive using it for that all the time. I was definitely wanting the mac5200 but the extra weight and noise wasn't worth it for me. Have bigger compressors in the shop needed something more portable.
Definitely give recommendations for the mac2400 to anyone who was looking at them
IndyGarage
Indy
Yeah, as far as I can tell, Makita LXT has the widest variety of tools out there. The only thing they are lacking over Milwaukee is their selection of battery powered LED lights.
oflannabhra
KY
They are coming out with a full range of these (up to 10k lumen) in 2020. There’s a video linked earlier in the thread that shows them off at a trade show.
oflannabhra
KY
IMG_2392.jpgI just picked my upgrades. XPH07Z and XDT14Z impact, case, charger, and 4 x 5.0Ah for $280
