Malco Turboshear Single ? or ? Doublecut ?
Marctrees
TX/LA border - Toledo Bend
Malco/ Kett Turboshear Single ? or ? Doublecut ?
For typical R panel and corrugated roofing/ siding panels.
To make straight cuts, where BOTH pieces will be used...
For nicest edges on BOTH pieces.
Did the research I could..
Seems double cuts slower than single, but will make BOTH edges clean.
Regular single cut seems to often distort the "Drop" side.
Am I right ?
What experience do you have ?
Will be using infrequently.
Not everyday production.
No, I don't want the HF model.
Malco ******** new, or maybe Kett w the motor if someone has a gently used one.
Marc
mik386
Northeast Ct.
You are correct. I am an HVAC fabricator and double cut is the way to go. They are not as maneuverable as single cut when making turns but it can be done.
danski0224
Near Naperville, IL
Neither of those will cut corrugated panels well, if at all.
Yes, double cuts leave a (relatively) distortion free cut on both sides. A Unishear will leave less distortion on flat metal than the Malco turbo shears.
A siding table is the choice for straight or angled straight cuts in corrugated panels/siding/soffit. A circular saw rides in a track, and the track acts as a guard to keep the panel from being pulled up too far. These run about $1k from Tapco or Van Mark.
There are profile metal nibblers, they are expensive and will not cut through double thickness like a hem or catch (female lock seam).
bullnerd
Jersey
I have the malco single that you add onto a drill, yeah it leaves a very wavy edge on one piece.
You can cross cut with it, but again, not a nice finish.
For me, a novice with these panels, the diablo metal blade in a circular saw leaves a way better edge. But NOISY!
bradpac
Central TX
Finally something on this forum I know enough about to contribute on.
I work for a metal roofing manufacturer/distributor, we sell and work with these tools everyday.
The Malco Turboshear is easily the best choice, it works well, and its hard to beat the price over a dedicated shear, but Kett does make some good tools if you want to spend the money.
For cutting panels with corrugations, the single cut is the way to go. A double cut won't maneuver over the corrugations, especially in a wavy corrugated profile. Double cuts work well on flat metal.
Most of the guys that use them around here for walls cover the edges of the material with a hemmed flashing anyway so the little bit of waviness the single cut leaves behind isn't seen, and on a roof application it is too far away to be noticed.
You could also use a metal cutting saw or saw blade, it will leave some burrs, but its a pretty clean cut, you just have to make sure to clean up the metal chips left behind or they will start rusting quick.
jgromada
Maryland (between DC & Balt)
There is no doubt a dual cut will be better if you need a nice edge on both pieces. I had roofing panels to cut and only one model TurboShear (Malco) had the depth of cut to handle the raised sections of panels. It worked well but once again I only needed the main part of panel
