Man door sizing question
famous187
Evansville, IN
So , my friends and I built a 15x17 room in the corner of my pole barn. Its time for me to hang a man door and these are the frame dimensions:
35 3/8 WIDTH
83 3/8 Height
When looking at doors on Menard's website is lists the following:
32" Door:
Rough opening : 34" x 82 1/2"
34" Door:
Rough opening : 36" x 82 1/2"
Questions:
I'm assuming that a 34" door won't fit, would that be correct?
If I have to use the 32" door, my opening is a bit bigger than the rough opening size specs. Is this ok or will I need to build up the frame first?
Thank You for any help!
tjdux
Southern Nebraska
Man everytime i frame anything i get the door first just to keep this from being a thing.
That said the gap for a 32 inch door is acceptable and thats what shims and trim us ment for.
If your framing is good and square then you could maybe buy a NOT prehung door thats 36 wide and then rip it to fit and hang directly to framing...
There are probably a 100 or more differnet ways to solve this problem and those just are my thoughts.
Good luck
ducksface
Change your opening to fit the widest prehung door you can afford.
Do not let some arbitrary hole in your wall dictate to you.
Then skin it with dry erase board.
MikeinNorthWales
SE Pennsylvania
My first thought- What made you decide on an R.O. size as odd as that?
My second thought- What is the room to be used for? Will you be moving equipment or furniture through it? Would a 36" door (my preference) be a better choice? If so, reframe to the required R.O. and buy the door YOU want, not what will fit. If a 34" will do, I say reframe if needed. 32" is getting kinda small.
Sent from my SM-G935P using Tapatalk
Thumper68
Duluth MN
I would re-frame to a 36 inch door, the new home we are designing will be all 36 inch doors just in case one of us ends up in a wheel chair, not to mention it is much easier to get things through them. But I like the barn door idea for a room in the shop as well.
Stuart in MN
Minneapolis
Take a trip to your local Menards with your tape measure and measure one of their 34" doors to find out exactly what width it is.
wssix99
Chicago, IL
+1. I have a 36" door and often wish it was larger as I come and go with stuff. Now is the time to make it right.
yeldogt
If you want to be able to bring things in and out ........You want a 36" door -- trying to bring things in through a 32 will be a pain. 34 is normally a special order -- silly choice.
My door in NYC is 40" -- the extra space is nice
jetnow1
CT.
Yes a 36 inch door is nicer to carry things, but it's a garage- It has garage doors if you need to carry things in that are larger. Is the rough opening in the wood or is it what the
concrete guy's left you? Wood is easy to change, concrete is doable but harder. 35 3/8 might fit the 34 but you would have to have a perfect opening as there would be no room for shims etc. By the way I always adjust the framing on the hinge side so I do not need shims on that side before door install, gives you a much nicer solid install and you can replace all the hinge 3/4 inch screws with longer ones into the frame. This reduces the later problems with the door sagging and binding.
yeldogt
He is building a room within the barn. Not clear if the door will be inside the barn or to the outside ... I would think in the barn. It's the only way into the room.
The Tool Tyrant
Bonita, Ca. (San Diego)
Hey Famous, you need to be clear on your terminology...when you state "Frame size is" are you referring to the 'rough opening' or you installed a Non- Pre-hung door frame and the dimensions you gave us are of the installed frame. :dunno:
Falcon67
Merkel, TX
X4 or 5 - re-frame for a 36" door rough opening. 32" OK for a broom closet, not for anything else.
Catadj78
Alabama
I agree, re frame to a 36".
I have 5 man doors in my 40x40. 4/5 are 36" the other is just a small closet. I even went with a 36" in the bathroom in case I had to pull the shower enclosure out
shelteredV
The Rock
I would reframe for a 3'0" x 84" door. The R.O. will vary depending on who makes the door, jamb size, ect. Always try to make the opening bigger rather than smaller, it's much easier to shrink an opening than enlarging it.
benjamintmiller
IA
To answer the question that you asked, a Menards 34" prehung door is usually about 33 1/2" wide to allow for some shimming on each side. It would not fit or would be really tight in a 33 3/8" opening.
I would install a 32" door, using some 1x or 2x material as shims, and be done with it. 36" wide doors are really wide and look strange indoors, IMO.
NUTTSGT
Northern Central Ohio
Or you fall in the shower and break a hip. It's a lot easier for the EMS crews to get a cot through the door or carry you out on a (no offense) mega-mover. :wtf:
TractorJeff
Elkhorn, WI
Its a room in a Pole Barn!
Rough it out to fit a 36 inch door!
My brother's previous owner built a room for a Cabinet/Carpenter Shop in the Pole Barn. One wall had a doorway at 36 inches and the other wall had a double door to get projects in and out. The 3rd wall had windows so he could see the house and driveway, reserving the 4th wall for hanging tools on!
Didn't look GOOFY!
6768rogues
Western NY
Who the heck framed it with an oddball sized opening? I would at the least reframe it so a 36x80 door would fit so things can be moved in and out. I would rather frame it so a double door unit would fit so I could use a pallet jack to move pallets of stuff in and out.
Stuart in MN
Minneapolis
The OP said his framed opening is 35 3/8", not 33 3/8"...
The dimensions quoted from Menards are for the recommended rough opening size, which is a little larger than the actual door frame size to allow for shimming. The actual width of his framed opening is only 5/8" more than the recommended width, so a 34" door and frame may still fit. That's why I said earlier to go to the store and actually measure the door frame in person.
The Cobbler
so the OP asks a question basically whether a rough opening will fit a certain door size.
most replies are telling him to redo his framing so a 36" door will fit.
not knowing the purpose of the room, weather he actually has the space to enlarge the door or any other factor.
TractorJeff
Elkhorn, WI
WELL? :headscrat
Because he asked in the INTERNET that's why! :beer:
Worse even more so he asked on GARAGE JOURNAL where its got to be BIG or the BEST whether it fits or not! :lol_hitti
As far as the door fitting, surely he owns a table saw, he can stop sweating details and cut it to fit! :lol:
ducksface
Because ANYONE could have bothered to take the three seconds to get 1,000,000 Google answers to his question. So unless he just couldn't type in
What door fits a *** opening,
he was looking for opinions not answers.
The guy who said he wanted a riding mower to take his infant for frequent rides didn't ask an opinion either.
But just as in this thread, we would be remiss if we didn't present what are appearing to be unknown facts to the unknowing.
Fact is
Is a special order size(per some here) and a less than ideal idea and installation as per most here.
Sawdustmaker
Placentia, Orange Co., California
What about a sliding door? Barn style?
This is a good idea as long as the door does not go to the exterior. You can build your own door (like I did) and make it any size you want. For ease of movement reframe the opening, go with a sliding door (if not to the exterior and you have the room) and make it 42". You won't regret it. FYI I built two 42 " and a 36" door for my sliding barn door project (interior). Check for track and trolleys on Amazon. With a sliding door your track needs to be at least twice the door width. So 42" door = at least 84" track.
Catadj78
Alabama
:lol:
I've not actually taken a shower in it yet (plumbing) but I really believe I purchased the very smallest shower they make. I'm 6'2 215, I don't believe I could actually fall all the down in the shower. But I can get it through the door.
Falcon67
Merkel, TX
:lol:
you could do what we did at the old house - buy a complete one piece 32" shower unit, then get home and realize the door on the bath is 30". 30" was a lot in 1924 apparently.
kbs2244
It looks like the consensus is to remove and reframe
IMHO, I would advise the same.
Now is the time to do it.
I would even look into surplus sites for a removed 40 inch commercial door.
For sure this is a time when bigger is better.
6768rogues
Western NY
Most of the old houses around here have at least one 36" door because they used to have funerals in the dead guy's home and they had to get the casket through the door.
lakeroadster
Central Colorado
Questions:
The first reply is your best answer. The GJ is turning into the H.A.M.B. WTF? :headscrat
the 34" door may fit, depending on how plumb your framing is.
32" would fit, and all you need to do is shim up the framing a bit.
rayra
Escaped from Los Angeles
Change your framing. 2 studs and a new header. Instead of putting a tiny / narrow door in. Go 36".
First time you try to carry something in and bash your knuckles you ought to feel like an idiot.
F
famous187
Evansville, IN
wow. thanks for all the replies.
just for some info, since lots of different opinions came up,
i like to work on cars, trucks , boats and firearms. i dont know much about framing or any of that and don't really care to. i had a buddy help me frame the 15x17 room a few months ago and i'm just getting around to the door. i told him to just match the opening for the 36" man door leading into the barn, but for whatever reason, he didn't. so that's how i ended up with the oddball size. since I dont know much about this, my question was just simply, if a 34" door would fit that opening and if not, would a 32" fit without too much work.
the room has a 10' countertop work bench that i reload ammo on and work on guns, a 60' led tv, a couple cabinets for storing stuff , a couch and a barbers chair. just a place for me to relax and hang out with some friends. all that stuff will fit through a 32" door.
i went and bought a 32" prehung door from menards tonight. the 34" were special order so I couldnt measure one. looks like the 32" will fit with just a little work.
the 32" door will be fine for what i use the room for. thanks for all the insightful AND entertaining responses.
wssix99
Chicago, IL
i had a buddy help me frame the 15x17 room... i told him to just match the opening for the 36" man door leading into the barn, but for whatever reason, he didn't.
For all the thoughts that went through my mind of shooting the "helpers" who screwed up stuff on my house (many "features" of which I am still fixing...), this guy should have been more careful working on this particular room.
NUTTSGT
Please tell me that you didn't buy one those $50-some dollar white press-board doors. I put one on the garage bathroom which was fine but the door separating each side of the garage was a mistake. Any time I shut that door, I kick myself in the ***.
rockettgpw
Sunshine Coast Qld down under
Ha! same on this side of the pond, the original bathroom door on my 1926 bungalow was 30" when all the rest were 32". Relocated the door to the new en-suite where the size looks right. The en-suite has french doors to outside which made it really easy to get the cast iron bath in.
MikeinNorthWales
SE Pennsylvania
I tried, very early in this thread. Apparently I'm invisible on this forum. Whatever...
