mike93lx
4 systems on site, two 2.5 ton a/c's, a 1.5 ton a/c and a 10 ton pool heater. One one side of the house, I have the pool heater and existing condensate drains for the two 2.5 ton coils. On the other side are all three a/c condensers and the condensate drain for the 1.5 ton coil. Soil is poorly draining clay and the lot is very flat.
I have the pool heater and 2.5 ton coil condensate drains dripping into a channel drain that gets the water well away from the house and yard.
The 1.5 ton coil condensate currently drops into the yard, about 3 ft from the house and it's always wet in that area. I'm replacing the two 2.5 ton systems with heat pumps, so I'll have even more condensate over there and no great way to get rid of it.
I may have to put in a dry well or two, but I am worried about the amount of condensate I'll have and how slowly the soil drains. In order to get it into a downspout drain that is about 30 feet away, I would have to pump it, but to protect the pump from freezing, it would have to get buried. I don't mind doing that if I can get a reliable setup.
Any experiences and recommendations?
TL;DR flat lots ****. I want some slope
