Kaizen
I've done a bit of plumbing and having an issue finding an answer so hoping someone here knows.
I have a 3/4 line coming in and put a new heatpump water heater and maniblock within ten pipe feet of the entrance after the meter which i am assuming has a backflow preventer making my house isolated.
I cut out the mess of 100 years of copper and ran new pex. I've always had a little pipe banging when the washer runs but now i notice it more as well as the dishwasher. My water heater install says to install an expansion tank on the cold line going into the tank. Now the questions
- Should i just run the standard big boiler size off the shelf at Home depot and check my water pressure/adjust?
- Should I run two smaller ones on hot and cold at the maniblock inlets which are after the hot water inlet?
- Can i use the 1/2 Maniblock extra port/s to run up to an expansion tank? In theory it would see the whole system but not sure if having on a bigger pipe size makes a difference?
