Manual charger for electrolysis
branimal
Would something like this be good for running electrolysis to remove rust from metal?
Guy wants $35 for it. Apparently it’s very difficult to find manual chargers these days.
An alternative is to buy a Dc power supply. Or rig up an old computer power supply with alligator clips.
laser3kw
northen IL
my neighbor has been using a charger like that to do electrolysis for over a year now. He gets great results. As long as it still works, $35 seems goood
branimal
Thanks. I’ll test it out with my multimeter.
firebirdparts
Kingsport, TN
You bet. I guess those were made by Schumacher, but that's just a guess. That is a really nice charger for any purpose. I don't know about the whole "manual hard to find" is true or not. I haven't tried.
sick467
Hughesville, Mo
It would work fine for basic electrolysis in smaller vats (like buckets or storage tubs). How big of an operation are you planning and what are the charging amps of that unit?
dogdog
Dependents on what you are derusting and what amp that charger is capable of…. Maybe check your lower east side ecology electronic recycling center, that thing $20 but not $35 Or just go eBay Amazon and buy a 24v smps. If 12v a minimum of 5amp capabilities or 24v with 10amp if you are doing large radiators.
branimal
It’s says 10/2/50amps on the faceplate.
Some small projects in tubs. But a big project would be stripping rust from the underside of a metal parts cabinet. I have a some cement mixing tubs for that. And a custom made tub with a shower liner bottom.
Another big project would be stripping rust from a cast iron steam radiator.
Picture is the bottom of some metals parts cabinets I picked up. I’d like to remove as much rust off that with electrolysis.
Shiftless
East Bay SFO
I have a very similar charger. It delivers a max of 10 amps continuous. There is a “start” function that you can use for a few seconds to start a car. That function delivers what they say is 50 amps. I have used it but never measured the actual output.
matt_i
You don't need an exotic charger. Just run a 12v battery to the anode and cathode and let the charger keep up with the battery. I think I have a 1 or 2 amp charger that works just fine, derusted a tractor's rim that way, a little at a time.
I do like the Evaporust better, less involvement pre and post treatment but its also slightly more expensive.
Bretny
Dutchess county NY
Transformer based battery chargers are a bit harder to find as they have mostly gone to smart charging. They do still make onboard RV chargers that are transformer based as well as ham radio power supplies. Generally these start at about $100.
Bretny
Dutchess county NY
I'm sure evapo rust works really well but the cost to remove rust in a 4gal generator fuel tank could cost more than the machine is worth.
Stuart in MN
Minneapolis
Those older chargers are generally built like tanks, and should last you forever. $35 is on the high side, but we're not talking about huge amounts of money here...maybe you could find one for $20, but that's only a $15 difference.
firebirdparts
Kingsport, TN
laser3kw
northen IL
They are different. If you don't connect the home Depot one to a partially charged battery, it won't come on.
yes - anything with "battery recovery", "smart" technology needs to have 10.5~11 volts before they will do a charge routing. I found this out the hard way. Had a lawn and garden battery that was new but sat on the shelf for a couple of years. Had to charge it with a "stupid" charge to get it where the "smart charger" would finish it.
metaleltr
Western Ohio
Evorust is not one time use. After using it to clean that 4 gallon fuel tank it can be poured into a bucket to soak other rusty parts in later.
branimal
I have not used evaporust . I have seen it used on you-tube tho...
I get fine results with electrolysis , at basically zero cost
Interesting point. How much does the electric cost? I was wondering if my con Ed bill was going to jump when I start running the process.
mikegt4
sw ohio
I use an old Sears (Schumacher) charger identical to the one in the OP. Works great even for larger items.
Bert_
NW Iowa
Guessing about 100 watts of power used. That would be about 8 amps from a 12v charger.
In my part of the country with electricity at about 12 cents / kw, it would cost just under $0.30 a day.
metalmagpie
Seattle
I have done electrolytic derusting for many years. I started out using little Schumacher battery chargers and the like. The problem I had with every one of them is that they are not built for continuous use. After a few days they burn out. I do not recommend these battery chargers.
I bought a real DC power supply about 15 years ago and it has served me well. This one:
https://www.volteq.com/volteq-power...30a-over-voltage-over-current-protection.html
Not cheap, but a very good tool. I have found it to be well worth the money.
Here is a typical setup in my hobby of restoring machine tools:
Workpiece before:
And after:
The pain of paying for a good tool fades soon. The misery of buying a cheap tool lasts forever.
metalmagpie
boyleged
Cincinnati, Ohio
I bought both of the harbor freight chargers trying to figure out electrolysis. Neither of them worked, I guess they have circuitry now that only let it work if its connected to a battery. I finally traded my dad for his old charger so I could de-rust old Estwing hatchets and Japanese kitchen knives. Around here $35 is a good price from FB Marketplace or CL
branimal
There are some videos on YT on how to hack the HF charger into a manual charger for electrolysis.
branimal
are both of these chargers considered manual chargers?
I believe the schauer battery charger is manual.
Thanks.
