Manual "force" compressor start
manoweb
California
Hello, I have a common 5HP, 60gal dual stage compressor. I recently swapped the pressure switch because it got "sticky". No big deal, less than 30$ from amazon same day delivery and few minutes to connect it.
I was wondering - my compressor stops pumping at 165PSI and starts again at around 120PSI. I know I can change those values with the adjustment screws. However, for example before I start cutting with Plasma, I often would like to "top up" the compressor. Let's say it's at 130PSI, I would like to manually force it to start and fill up to 165, then do my thing. No I never had any issue, I just prefer not to work while a loud compressor is pumping.
Is there such thing as a pressure switch with manual "force" start? In principle it should be pretty simple but if it exists I am not sure how to search for it, thanks.
manoweb
California
Yeah I often release pressure to start it but it's a waste of energy and time. And yes, it's the "CENTRAL PNEUMATIC 60 gallon 5 HP 165 PSI Two Stage Air Compressor (Item 93274 / 62299 / 96598)" a very, very common compressor (pump is Made in Italy)
I thought there would be pressure switches with an extra button or lever to just force start them. If that is not the case, oh well, I'll survive :)
Fixr
SW VA
A switch that overrides the pressure switch would be a liability nightmare, especially if it were to stick or get tied down. It's just a really bad idea all around.
micromind
Fernley, Nevada, about 30 miles east of Reno.
If the switch has a built-in unloader valve, even if it's in use, often you can manually push the tab that operates the valve and it'll start the motor. You don't need to hold the valve, just 'trip it' so to speak.
Then it turns off at its normal shutoff pressure.
manoweb
California
Hello, if you say this, it means you really have no idea what I was asking. If I wanted to bypass the pressure switch I would have simply bypassed it
manoweb
California
Oh we are onto something here... yeah of course I believe virtually every pressure switch for this class of compressor have a builtin unloader valve... I need to inspect how that tab works. And of course, it has to be a momentary action like you describe
KenC
oklahoma
You could replace the current setup with a motor starter that has a relay operated start function and a manual start button. That would also take the high current load off of the pressure switch since it would only be driving the relay coil.
Norcal
The mag starter on my compressor would weld the contacts & continue to run, when the safety valve would let go go, knew it did it again, replaced the contacts & still continued to do it, got rid of the NEMA size 2 Westinghouse A100, starter in favor of a Furnas ESP100, it's never happened since but always have been thankful for the protection of that valve.
Fixr
SW VA
Ah. I thought your use of the word "force" might be meaningful. Never mind.
4x4Pete
Stroud
I would use the motor starter as suggested by Ken C. Adding in a normally open solinoid valve that closes with the starter, and a compressor style check valve with the bleed port. This would unload the compressor each time it shuts off. This is exactly what I have. The compressor was from a large multistory building for pneumatic controls. The tanks were remote (which it still is in my application). The unloader was a solinoid wired into the starter and plumbed to the side port of a check valve where the piping left the floor mounted compressor heading to the tanks. It can be done safely.
mikegt4
sw ohio
It sounds like this question is making a mountain out of a molehill. As the OP stated he could adjust the pressure switch to restart the motor at a higher pressure (easy to do) but only wants the restart to happen occasionally, not always. In the same scenario I have just pulled the little ring on the pressure relief valve to dump some air pressure until the motor restarts. It does make a lot of noise but it also serves as a test showing that the valve isn't seized (legitimate justification for doing so;)). Opening the tank drain valve would achieve the same result.
KenC
oklahoma
so your start button is not connected to the pressure switch. how does the compressor shut down?
Maybe I wasn't clear enough. The installation uses a starter with a 120v coil. that coil has it's power provided by the pressure switch, and in parallel a start button. So either does the trick. Common configuration
BurtEggley
There needs to be some kind of fail safe in the set up I think it a button can start the motor anytime it is pushed, even if the motor only runs for three or four seconds because the primary contactor is open and at its max. There is always one idiot or juvenile who would keep hitting the button to see how high he could get the pressure, or burn the motor up first from constant pushbutton starts.
