Manual trans fluid help
johnasosajr
Here goes,
I am replacing a clutch in a 2008 Chevy Aveo I am going to change the transmission fluid while I have the ****** out it calls for 75W 90 GL3 fear oil I can’t find it anywhere except the dealer for almost 30 dollars a quart can I use 75W 90 GL4?
Ole Slewfoot
Freedom, CA
Good chance that car takes an oil which meets GM standard or the synchro facings fail.
I think coast and castrol make it.
kelpaso1
MEMBER EMERITUS
New Brunswick
I used to use GM Syncromesh fluids in my Jeeps. A lot thinner than gear oils and easier shifting in freezing cold weather.
ex-x-fire
Sheboygan Falls Wi.
Make one of these for filling those components. I made a couple for our shop at work but I used 3/8 id clear hose and it flows a lot faster then the set up in the video. I used a 3/8 metal line bent into a J to put in the hole. Real time/mess saver for sure.
joe_pinehill1
Northern Virginia
I would buy the GL from the dealer. Fluids are one item I find dealers dont mark up too much, and if you ask for a discount I usually get one. The different GLs have different additive packages.
skruft
I have found that I had to do some research on these oils, to see for sure what was within spec., esp. when I had a Jeep that specified all different oils for the axles, manual trans, transfer case, etc.
engineer2
Chicago burbs
I used to use an enema bucket to fill transmissions overnite. Very hand if the trans is already installed or is an old 4 speed with a side fill plug.
slip knot
Texas gulf coast
I use the garden sprayer like the video. except I go from the valve to 1/4 copper tubing bend a slow 90 in it. Will push a gallon of 90wt in @ 3minutes.
