tomherrick
Was doing some soldering and my old bottle of MAP-Pro gas ran out. Got a new bottle, threaded on the nozzle and lit it. After about 10-15 seconds there was an orange ball of fire surrounding my hand; no pressure, apparently just leaking fuel on fire. It appeared to be coming from the bottle-nozzle connection. I turned off the nozzle, took it outside the shop, and it went out. I assumed I didn't have the nozzle tightened sufficiently, so I took it off, looked for dirt or debris, found none, put it back on, lit it, and got the same flareup.
I'm not terribly experienced with using gas or the nozzles. The nozzle was one my wife bought to use MAPP gas for glass bead making and could handle the more intense heat. I didn't know that MAPP gas had been discontinued. The propane torch I started with just didn't put out the heat required to solder the heavy copper fittings. The bigger torch nozzle worked fine - with the old bottle.
Since the nozzle worked with the old bottle it seems likely that I got a defective Map-Pro bottle. On the flip side, I kinda doubt that Worthington Industries puts these out without some QC. Ideas??? Suggestions???
