Marine grade electric shrink wrap tape
Rory Bellows
Does this exist? I have been using marine grade shrink tubes from harbor freight and they work great. Is there a marine grade shrink tape that offers the same results as the tubes? Everyone bashes HF but the marine grade electrical shrink tubes are the best at a good price point. It truly is a perfect product from HF. I would love to find a tape version that offers the same results.
rick carpenter
Huntsville, East Texas
A good while back I repaired a power cord with rubber self-fusing tape and electrical tape covering it like mrborohachi described. Being as my cord was cut half in two I was able to add real shrink wrap "caps" over the electrical tape ends. It's been weather-tight for a couple of years.
But I sure wish there was a true shrink wrap tape product like you're looking for too!
FigureItOut
Bentonville AR
3M 2228 is about the best moisture sealing tape I've come across. The recommendation I think is to stretch it until it's 3/4 its normal width. Applied correctly, it's pretty damn good. Temflex is commonly used, but the 2228 is better.
The reason you wrap it in vinyl tape after is the the silicone tapes aren't UV resistant and will break down in sunlight. I also like to use a layer of regular vinyl tape over it to keep the end under tension until it fully fuses.
Edit: I read 3M's data sheet after posting and evidently they say it's UV resistance is adequate. In my experience though, it is very, very easy to cut, so a good vinyl tape or Tesa tape over it for abrasion resistance is a good idea.
Sent from my XT1575 using Tapatalk
oldldh
Fairhope, AL
We used to seal our antenna leads with rubber tape, covered by electrical tape, and painted with "Marine Shellac"...
No moisture ever got in, that I know of...
Three layers of rubber tape, three layers of electrical tape, and three coats of shellac...
Water proof, me thinks...
A layer or two of shrink tubing before the rubber tape wouldn't have hurt...
R
Rory Bellows
I don't think a tape version of marine grade shrink tubes exists. Too bad. In my head it would work great and bond to itself. Maybe it doesn't bond to itself that would explain why it doesn't exist. Many times I could use a product just like what I envision in my head. Some chemical engineer should be tasked to create some. I would buy some and I think many others would too.
3M 2155 Rubber Splicing Tape
3M™ Temflex™ Rubber Splicing Tape 2155 is a conformable self-fusing rubber electrical insulating tape. It is designed for low voltage electrical insulating and moisture sealing applications. Compatible with solid dielectric cable insulations.
OR
3M 2242 Linerless Electrical Rubber Tape
Scotch 2242 Electrical Tape is an economical, general purpose, rubber tape. The tape is a highly conformable, linerless EPR (Ethylene Propylene Rubber) based electrical insulating tape. The tape is designed for use in splicing and terminating wires and cables rated up to 90°C. The tape will meet industry specifications for flame retardance and has the necessary physical and electrical properties to provide immediate moisture seals and void–free buildup.
