Marine instrument wiring
Lumpy102
Ontario Canada
Looking for a suggestion, I have a wind instrument up the mast on my boat, very fine wires (looks like about 5 hairs in each, maybe #24 or #26) run down the mast and into the cabin where I need to break the wires to remove the mast for winter storage. Raymarine provides a nice little plastic box with very fine little screw terminals in it to make the connection. I'd like a 5 pin weathertight plug that I can simply unplug in the fall. Anybody have a suggestion?
L
Lumpy102
Ontario Canada
Suggest sticking with the setup provided by Raymarine. Takes only a few minutes each season.
So part of the problem is that as I age I don’t see as well, and it’s a real pain in the **** to try to get those wires that I can’t see twisted and stuffed under a screw that I can’t see, hold them in just the right spot, and tighten the screw.
ez-duzit
Marina del Rey
At 81 I'm having similar difficulty. :) But I work on boats and understand this particular issue. Get a pair of drugstore magnifying/reading glasses and a headlamp to aid the process. It won't be any easier to install a plug and socket.
nadogail
Coronado, CA
Could you use a DIN connector? I don't know if you could get a weather proof version, but i think that they would have enough pins.
Maybe a connector set for Trailer Lights.
no704
Get some ferrules for the wire ends and a crimper. Yea new tools! And some Wago blocks.
SaintPanzer
Is that a NMEA 2000 wind instrument? NMEA 1983? Of which Raymarine instrument are we speaking?
Firebrick43
West central Indiana
We use M8 and M12 connectors an industrial equipment, and they are pretty good even in water based coolant and oil but I have seen them have corrosion issues in outdoor chiller towers and tank level cell monitors
I personally would use deutsch DTM connectors with solid machined sockets and pins. They are the best weatherproof connectors I have used (even better than metripak/weatherpak) until you get stupid expensive with Cannon plugs and Amphenol mil spec plugs.
https://www.amazon.com/JRready-Wate...onnectors/dp/B0B1ZDSWZR/?tag=atomicindus08-20
The machined barrel pins allow for you to solder in the wires if you don't have the correct daniels crimper as the housing strain relief is excellent.
SaintPanzer
See, the thing is, NMEA 2000 is is a very specific protocol, and one of the features is its ability to add to the network. For example, a three way connector can be added, and boom, you can add a GPS, or maybe an echo sounder, or whatever. The connectors I showed are IP-67 water resistant, and ensure the correct connection is always made. It's a trunk/drop line system that is plug and play. Sure, you could just splice the wires, or use a bus, or just twist them, whichever. But one of those male plugs, and one female plug, and you're all set, with the correct ability to move forward.
Oh, one other question: to what does the wind instrument connect? Is it a multi-function display? Gauges? How do you view the data?
As an example, on my boat, there is a wind instrument at the top of the mast which collects windspeed, direction, and a few other weather factors, as well as a GPS antenna. It also serves as the required end resistor. This trunk line travels down the mast, where it connects with a male end connector. This trunk connector plugs into a T connector, where it picks up the paddle wheel for boat speed. A bit farther along the trunk is another connector for the echo sounder. Because I wanted to listen to music when I sail, I added a sound hub, which also connects via NMEA. This all ends at my MFD, with various screens to view data. If I want to add to the mix (maybe an autopilot some day? Also considering digital inputs from the engine to record RPM, temp, oil, etc. All just plug into the trunk, and the MFD displays it all. Even if you're not using that all right now, or have no future plans, the shield wire is doing a bit of work for the network. It's important to use the correct connectors.
Amazon does carry the correct connectors. This is the male:
The photos better show the connectors. Strip the wire, loosen the crimp screw, feed the wires, tighten the screws. When finished, the "back of the terminal screws in, pulling tight the strain relief/water proofing seal. There is a little card showing which wire (color) goes where. The female is similar, and then the two connectors screw together. If you add to the trunk, there is a three way connector, the additional line goes in the "T", the male into one end, the female into the other and then on down the line. Here's the female:
