Marking lines on smooth wet surfaces- options?
danski0224
Near Naperville, IL
I am looking for something to make lines on smooth painted metal, typically with a plastic peel film on one side. Sometimes, it has either drops of water or it is wet. And it has to work in all typical jobsite temperatures- especially cold. The line I am looking for is standard Sharpie width- about 1/16" or a bit smaller.
It has to be visible so the line can be followed with a grinder.
I have tried the regular markers that claim to work when wet, and they don't (nope, not even the Milwaukee ones). Certainly not through much more than a few very small drops of water. Forget about actual wet use.
I have tried several brands of lumber crayons (DeWalt, Irwin, Markal) and besides being wide, they do not work so well below 50 degrees or so. The Markal ones are especially hard and do not mark well for me, even on concrete.
Tried the Fastcap "Fat Boy", same results with the crayon.
Solus has a neat pencil called the KB 24 and it creates a blue ink when it gets damp. This is really awesome, but the blue ink would work much better on something porous like wood because it doesn't stick to metal.
Solus has a yellow lead pencil that is not readily available in the USA- not sure if it would be better than a typical lumber crayon. Ordering some from overseas would be expensive if they do not work for me.
I have tried the carpenter pencils available at the box stores, and the lead is too hard. They do not mark well on the plastic film, or the painted surface underneath.
Solus has two other pencils I can get locally, and I may try them next.
Any other options? Thanks.
doctordirt
How about yellow paint pen. Often salvage yards use them to mark their parts. Marks on oil covered parts
JimNC
NC
Grease pencil maybe, don’t really recall if they skid on water or push it out of the way, been a long time.
D
danski0224
Near Naperville, IL
The panels are corrugated, so scribe/knife won't work for me. Some of the marking is freehand parallel to the corrougation.
Yes, on flat work I use a scratch awl.
I haven't tried a China marker yet.
Air21
Dykem makes a whole assortment of marking pens, sterile ones that won't promote corrosion, threaded ones that go in automated marking gizmos, ones with different kinds of ink solvents...
I googled around for a minute and didn't see anything that specifically solved your problem but there were a lot of options.
Davefr
OR
I'd recommend Stabilo yellow marking pencils. I haven't found anything they won't write on. The marking is not permanent and can be removed easily.
The only disadvantage is that the marked lines aren't real fine. (unlike Dykem layout fluid and a scribe)
https://www.dickblick.com/products/stabilo-all-colored-marking-pencils/
https://cdn.****-blick.com/items/204/08/20408-Group-2-2ww-m.jpg
BFBOB
China Marker?
Kinda crayon-like, line width 1/8". Pretty much mark on anything, but not permanent - on a nonporous surface, can be wiped off.
Cheap, worth a try.
Sloper0204
UT/WY
D
danski0224
Near Naperville, IL
D
danski0224
Near Naperville, IL
I have used those silver welders pencils before, and I do not think they are a good option in this case. The lead seems to be just as hard as a typical construction pencil. In my experience, they work really good on stuff like hot rolled plain old steel but not so well on stuff like galvanized steel sheet.
I tried the "universal" Solus pencil, and that is an improvement over a regular pencil. Iffy in water though. It works good on dry plastic film.
I have a few of the Stabilo pencils on order in different colors.
