Masking small holes before painting
pendragon1998
NE Georgia
When painting small parts, what do you use to mask small holes such as bolt holes and channels where spindles run through a part? I have used half of a q-tip to stuff down bolt holes, and rolled up bits of paper towels. I know they make special silicone plugs (too pricey for my project, but nice) and some people use silly putty (would that cause paint adherance issues?) What do you guys use?
P
pendragon1998
NE Georgia
half a q tip? What sizes we talking about stuff?? Pictures for examples?
This project is painting a hand drill frame, so pretty small holes. I need to mask the oil holes, spindle holes, side handle screw hole, etc.
ilovevocs
Toledo, Ohio
I use aluminum foil. That's how I mask key holes on auto door handles. I'll mask engine components with it. Honestly it does things masking paper and tape cannot.
Should work for what your doing. Use a pic to pull it out when your done.
If I wrap something with it I will wrap it a few times and terminate hard edges with tape.
Crusarius
Upstate NY
Vaseline. or other lubricant. Paint won't stick to it. Unfortunately it may sometimes be hard to clean around the area you just lubed for the paint to stick there.
toolchaser
Greenville, GA
I use silicone rubber plugs. The ones I use are used to fill gaps in Adel clamps when wire bundles don`t fully fill the clamp I.D. but I`m sure there are other sources...
P
pendragon1998
NE Georgia
I ended up using a combination of foam earplugs for the spindle channels and screw passages and q-tip stems for the oil holes. Happily, a long #10 machine screw fit perfectly into one screw passage and allowed me to easily manipulate the part. I think the paint job went off nicely. Thanks for the suggestions - what I didn't use this time will no doubt be useful next time.
First coat applied
Final paint job curing
sselander
CT
cork or rubber stoppers also work. Lowes has a good selection of rubber stoppers.
The earplugs from HF work for smaller holes since you can crunch them up.
