Master Extension Set
9GUY9
Mankato, MN
Has any one seen a master extension set? I prefer to have my extensions in a tray so they are easy to grab and inventory through out the day. However having several trays takes up a lot of space in the socket drawer. I would like to find a set that includes 1/4 3/8 and 1/2 extensions in a range of sizes up to 18 or 24". Like this http://cgi.ebay.com/ebaymotors/PRO-...t=Motors_Automotive_Tools&hash=item2a08544c07
but more complete, not wobble, and a real brand.
tweety652
i believe snap on sells them if you're willing to invest that kind of money
Bjkearns
what do you mean just one drive size?
one set per size
Im not sure how you cant have a huge variety of extensions when working on cars
doing spark plugs on a modern V-8 the 3/8drive set it very handy
here is a picture of my drive drawer
9GUY9
Mankato, MN
one set per size
I'm saying one set (all in 1 tray) that includes 1/4", 3/8", and 1/2" drive sizes. For the reason of taking up less space in the drawer than 3 separate trays.
Bjkearns
I dont know of anything with 3 sizes in one tray
I guess you could try making a tray so they you can have exactly what you want in it
use a router and the right size bit
9GUY9
Mankato, MN
that may be the best way to go about it. I as thinking of trying to mold the extensions into some sort of foam. But I like the wood idea, it would probably hold up better.
Stick Figure
Omaha, Ne
Time to get out some wood or plastic and a router, and make your own tray.
Personally i just keep all of mine on a socket rail. If you use a metal one it allows fairly easy removal by just lifting them up at an angle.
edit:
Guess i was a little late on my suggestion. If you check some of the industrial suppliers you can get a softer plastic that would be easily cut and hold up well to grease etc.
Bjkearns
for the 1/2 drive stuff I would go with impact extensions
normally if its that large a quick zap is much quicker for removal than a big ratchet or breaker bar
mrholeshot
MEMBER EMERITUS
I bash a lot of Craftsman tools (ratchets and China stuff) but if you want to come out on the cheap look into Craftsman extension sets. They have a good selection at a good price and you can buy a set of 3/8 for like 15 dollars (4 extensions in 1.5, 3, 6. 10) and then add a 20 inch and be out less than 30 dollars. About 25-30 on 1/4 inch an 35 on 1/2 drive. I've bever broke a Craftsman regular extension by hand. about 90 dollars would have you covered very well with about 15-16 extensions in three drive sizes. No fancy plastic tray but a solid set at a reasonable price.
mojo_13
Iowa
Here is a full Cman set for only $60 you get some swivel and adapters but between this and the 15% off with Bing (last day to do that at sears) would turn out being a good set for $50.
hay seed
Years ago HF wobbels where tiwan like gear wrench. I liked them so picked up a new set now china no ways as nice.
mojo_13
Iowa
I have that set. It didn't come with a storage tray, which is what the OP wants. When I got mine in the mail, they were in zip-lok bags, much like everything Sears ships...
I apologize, thank you for that.
mrholeshot
MEMBER EMERITUS
Storage trays are just a ploy by big tool box makes to justify you into buying a bigger box. God bless those smart bastards, lol
Bran Diezel
Bristol, Va.
man just go to advance down the street and buy a set of 1/4, 3/8 and 1/2. it will cost you like $60. they have the knurling on them and won't break the bank. i have mostly SO and Cman extensions at work. The SO are the best but will break the bank. The cman desperately need grip. I have one GW ext and we have hammered the hell out of it on the air gun and its never flexed
