I've been sort of in the market for an IR Thermometer. Is this one worth a flip? Do any of you guys have it?
http://www.tooltopia.com/mastercool-52224a-sp.aspx
That has an excellent spot to range ratio, 12:1.I've been sort of in the market for an IR Thermometer. Is this one worth a flip? Do any of you guys have it?
I was sent an email on this offer.
Before diving into IR"guns" please read these following links in order.
http://www.mastercool.com/media/52224-A-Inst_web.pdf
Note section on spot ratio, but more importantly on "emissivity"
http://en.wikipedia.org/wiki/Emissivity
Find out what exactly emissivity is
http://www.optotherm.com/emiss-table.htm
Find out that different materials have different emissivity
You will conclude a few things. Ultimate "accuracy" may not be the highest, your results will vary on how far away you are, your results will vary on angle, and your results will vary on material.
That said, I have used another cheap gun for a variety of uses.
Towing trailers, measuring brake/tire/hub temperature DIFFERENTIAL to spot various problems. Actual temperature isn't of so much concern as temp difference. Helps to find dragging brakes or under inflated tires.
Didn't work so well on exhaust manifold temp differential due to the nature of cast iron. Even when I did spot a difference on #1 cylinder, the reason could not be concluded. Could be just different amount of cylinder cooling there. Or could have been partially dead or rich or?
Worked decent to measure temp at tstat housing to verify it was open.
Did not work on aluminum ac lines due to emissivity.
Works GREAT when I make a wicked beer-chili. Slows cooks for approximately 1 week, occasionally adding more ingredients as they break down. Nice 170* temp.
Worked to verify the glass on my truck really was near 170* and the interior was over 150*.
Can sometimes use it to measure other blockages like I did with tstat.
Vent temp measurements can be a bit iffy.
It's not a themometer, it's a device measuring infrared emissions, which can be related to temperature.
