MasterForce (Menards) Tool Cabinets
mngundog
MN, in the sticks, U.S.A.
Never post here before. I had been watching the prices on these for 2 years and finally purchased the 36" and 41" ones when they were at the lowest I had seen. Now they dropped the price about another $40-$80 and then give you a 11% rebate. Price is good through the 8/4. The price listed is without the rebate (store check), so figure another 11% off.
http://www.menards.com/main/tools-h...rforce-41-roller-cabinet/p-1457698-c-9188.htm
http://www.menards.com/main/tools-h...rforce-36-roller-cabinet/p-1457697-c-9188.htm
http://www.menards.com/main/tools-h...-56-rolling-tool-cabinet/p-1457702-c-9188.htm
concealer404
Hrmmm... makes them cheaper than HF!
Thanks for posting! I think i'll pick up one or two 41s! (Unless someone says the 56 is that much better)
Hootbro
Delaware
Compare the shipping weights of the Masterforce and the HF boxes. The 56" Masterforce is 335 lbs and the HF is 536 lbs. I suspect the Masterforce boxes are thinner gauge steel.
concealer404
I suspect you're right. Luckily, they should hold up just fine for a weekend warrior like me. :)
Super Sport
West Michigan
Good deal! I was strongly considering these, but then found a good deal on a used SO box. If they made these in black I would already have one in my garage.
Super Sport
West Michigan
While I didn't measure the thickness of the steel, both feel equally solid in the stores IMO. HF is not known to be the most accurate with their numbers, so I suspect the weight is wrong on their website.
mngundog
I have never seen the 56" because it is never in stock, but I did compare the 41" many times to the HF one and after long consideration I liked the Master force one better. On thing to point out is if you are putting a lot small wrench/sockets/small items etc, into it the draw configuration is better on the 36". So in you are getting two you may want to get one of each. A nice feature of the 41" top box is the bottom draw* is actually a SS work base, its not shown in the pic but that bottom SS plate pulls out.
mngundog
Anyone have info on the rebate thing?
11% rebate comes on your receipt, you mail it in and get a post card in the mail which is basically a store credit check. If you had a dishonest postman he could steal it (basically a dumb idea), I have sent in a couple hundred of the rebates and received everyone. This week you get 11% rebate for everything in the store.
DekeT
USA
No net weight is given for the HF cabinet. Presuming an approximate same amount of surface area of steel then the HF cabinet would have to be made of 14 gauge. That seems like a lot for $800. The 56 in Masterforce is an incredible bargain right now at $500. + rebate
Hootbro
Delaware
I would bet a cold beer those numbers are reasonably accurate and the Masterforce box is a thinner gauge steel.
If you look at the pictures of the Masterforce box side view towards the bottom, it has lip roll of the steel and that is usually seen on thinner gauge boxes like the Craftsman stuff.
The $200 price difference for the Masterforce is there for a reason, it is thinner material.
moserjj
WI, USA
I was considering both places, HF and Menards Masterforce line. I was between the HF 44" for 350 and the 56" MF for 499 - 11%. I pick up the 56" MF tonight. I'm not a pro, slight differences in metal thickness are probably there but I just need more space. I also had about 150 in Menards rebates to burn so that made the choice even easier. I netted somewhere around 300 considering all rebates. Hard to beat
Hootbro
Delaware
No net weight is given for the HF cabinet. ...........
http://www.harborfreight.com/hand-tools/tool-cabinets-and-carts/56-inch-11-drawer-industrial-roller-cabinet-67681.html
Says right there, 536 pounds shipping weight. So unless there is 200 lbs of extra packaging than the Masterforce one, the HF is quite heavier. Maybe the HF box comes with a circus midget?
I think people here are overriding common sense due to the cheap price of the Masterforce box and making unfair apples to apples comparison when the published specs say otherwise.
mngundog
When you looked at the MasterForce cabinets, what did you think of them?
Hootbro
Delaware
I think it is priced right for what it is and would have no qualms buying one with the information that is known.
I do have to disclaim that there is no Menards near me and have not seen these in person.
allinon72
Indianapolis
Having played with both several times, the MF feels way sturdier than the HF box. The drawers close much more solidly. I'm not sure if the steel thickness, but I can tell you that it is not thin enough to be 200lbs lighter, no way. There is no way the HF box weights 500+ lbs empty.
concealer404
Buddy and i can lift the HF box by hand. I'm a pretty small dude and i'm not easily lifting 250lbs anytime soon.
Bull
I really would love a 56" box, but the closest Menards is apparently 479 miles away. Ballz.
DekeT
USA
No bet required. I would be happy to buy you a cold beer. :beer: Though you would have to drive 500 miles to get it.
jhelrey
MN
I have the 56 inch Masterforce and I have owned it now about 3 years. I love it
Travo131
Tomah,Wisconsin
I have a MF 41in box also. Its been great for me so far, the only complaint I have is when its cold out the drawers kind of stick and are hard to open.
ishiboo
Oshkosh, WI
Having seen both boxes, I think the HF's are still the better value and slightly better built, but the MasterForce boxes are extremely nice as well. Probably the #2 value to the HF's #1.
This coming from a HUGE Menards shopper.
jhelrey
MN
The HF one may weigh that with all packing materials, pallet, etc.
