Used this for about a year, still in great shape.
Don't want to get rid of this, but I'm out of work and just trying to be able to pay bills.
Goes for $1030 from Matco new looking to get $600 obo
DROPPING PRICE $575
Located in Seattle and shipping would be rather expensive, not light.
Here's the description from the Matco site:
MASTER SVC ROLL CART - SVN/BCM
* NEW & EXCLUSIVE MSC12 Master Service Rollaway Cart: BLACK SILVER VEIN WITH CHROME TRIM
* PICTURE SHOWN IS NOT THE COLOR COMBINATION FOR THIS CART... PICTURE SHOWN (TALON ORANGE WITH BLUE TRIM) CAN BE ORDERED AS A CUSTOM ORDER ITEM
* Fully welded unit... only assembly required is the mounting of the casters... Welded unit will hold up to the rigors of evey day use and can handle a maximum load for maximum storage...
* Built-In Lockable Storage in rear for PryBars, Screwdrivers, Hammers, Airtools... Over 1,200 cu. in. of storage in rear compartment alone...
* Dimensions of back component will allow you to store even the 42" Matco Prybar... and is large enough to accomodate the ergonomic large Matco Prybar handles...
* In all, you can store and lock up to 18 different tools in the rear compartment depending on your needs... Matching holding tray on back can be mounted in various positions to help you organize your tools exactly how you want them...
* All slides (including the sliding lid) are rated at 140 lbs. per pair... these are the same slides we use on our MB4725 Rollaways...
* Casters are 6" Diameter and rated at 600 lbs. apiece... The large diameter is the largest in the category and allow for easier travel over airhoses and uneven shop floors...
* 2,400 lbs. of caster capacity can handle a maximum load for maximum storage... these are the same casters that we use on our MB4725 Rollaways... Unit comes standard with 2 Swivel and 2 Fixed Casters... it can be upgraded to ALL Swivel Casters...
* Casters are mounted to hat-channel braces underneath the Rollaway Service Cart... this helps distribute the weight of the box through the braces (not the bottom tray)... so you won't see the casters protruding through the bottom tray...
* Sides of cart equipped with slots for hanging up to 8 airtools and 10 screwdrivers... These are not meant to be storage areas... but will allow you to load up your cart at the beginning of the day with everything you need for a day's work...
* Tubular Lock is high security and easy to use...
* Recessed tops on Sliding Lids prevent tools or car parts from rolling off... laminated work surfaces on the Sliding Lids can handle the rigors of every day use while protecting the paint on the lids and they can easily be removed for cleaning...
* Each Sliding Lid is braced with a hat-channel to give you a superior surface on which to work... Each Sliding Lid can hold 100 lbs. when open... even in an empty cart...
* Each Sliding Lid is 17.75" x 26.625" for over 470 sq. in. in work surface... so each MSC12 Master Rollaway Service Cart provides over 900 sq. in. of TRUE work surface...
* Top Lid Compartment is over 7" tall and has over 5,100 cu. in. of storage space... perfect for standing up the deepest sockets and many other tools that regular service carts can't handle...
* And since the prybars are not stored in this area, the entire lid compartment is flat from side to side and front to back... no more digging nuts and bolts out of the prybar pockets like regular service carts have...
* Two (2) Drainage holes with plugs inside Top Compartment (inside lid) and ONE (1) on the bottom tray to contain any spills inside each compartment and allow for easy drainage so spills don't drain into drawers and clean-up is much easier...
* Steel pegboard back allows you to mount hammer holders, spray can holders, pegboard hooks, and various other storage components which work with standard pegboard pattern...
* Maximum storage... the MSC12 Master Rollaway Service Cart is the largest in its category in the industry... Over 2,500 of sq. in. capacity and over 12,000 cu. in. capacity... Overall Dimensions: 43.75 H x 35.8 W x 26.75 D
* EXPANDABLE UNIT let's your turn the MSC12 Master Rollaway Service Cart into a full rollaway as your storage needs change...Bottom drawer unit allows you to configure your drawers how you need them...
* You can add over 2,300 additional square inches or over 7,000 additional cubic inches of storage capacity...
* 15-Step Prep-n-Paint Podwer Coat System and Anodized Aluminum Drawer Handles: Black Silver Vein with Chrome Trim
* Exclusive Super-Heavy Duty Premium Side Handle just like the Matco Tools 5-S Series Rollaways...
* Industry leading ONE (1) YEAR WARRANTY...
* As with all Matco Toolboxes, the MSC12 Master Rollaway Service Carts are made one at a time at our Jamestown, NY Toolbox Plant from the best domestic and global components...
Part#: MSC12SVC Price: $1,030.00
DROPPING PRICE $575
