Material Interaction
Rick_Br
Winston Salem, NC
I'm in the process of making a male tapered spindle to fit into a female taper socket. The female socket is a mild steel and the material I have for the male side is stainless steel. I don't know the actual grade of either material. Is there any risk of the two materials interacting is some negative way - weird corrosion, taper not releasing, etc?
Thanks
Rick
RoninB4
Under My House
-That might really depend upon the application. A well made, close fitting taper will "lock" on itself yet release with only .002 gap. SS comes in 2 basic groups, one being magnetic and the other non-magnetic. You likely have the no-magnetic type as it's more commonly available. Both types of SS are NOT impervious to corrosion. The non-magnetic (300 series) are resistant to corrosion in the presence of atmosphere. The magnetic group (400 series) will rust up like any other ferrous material like mild steel. So when you keep the two components together as a permanent assembly the corrosion will likely begin on one and transfer to the other. If you use them and disassemble it will likely be just fine. A light coat of oil on both will help prevent corrosion but may not allow the taper to "lock" onto itself. Since you don't describe the application it's difficult to make definitive statements about this.
RoninB4
Under My House
Sorry - the application is spindles for a State B4 spindle sander
Rick
-Well golly that sure was more information than describing how it's used, frequency of disassembly, doing a simple magnet test to determine what series of SS is intended for use, or even supplying a photo of the mystery equipment. Also nothing mentioned regarding how the taper is going to be made, how the female socket was measured, how fitting for a taper lock will be achieved, or how the tapers will be separated to avoid corrosion. I've already spent more time typing than the OP did, guess it's not that important to him either. Good luck.
R
Rick_Br
Winston Salem, NC
OK - so an oscillating spindle sander has an oscillation tube with a female taper socket in it. There are 11 or 12 spindles that hold either a rubber drum with an abrasive sleeve or the abrasive sleeve fits directly on the smaller spindles. I am making the male spindle tapers that slide into the female socket. The female socket is threaded on the bottom and there rods that go through the male spindle taper and thread into the female, This is called a postiv-lok spindle design by the manufacturer. Tightening the threaded rod pulls the male taper in and loosening ejects the spindle.
I determined the spindle make taper using an existing OEM spindle and my taper attachment on the lathe. In my world the male taper spindles will be removed after use so no long term storage of the assembled tapers. Hopefully my explanation above conveys the message that this is not a high tolerance spindle fit - on the few I measured the run out on the spindle was in the neighborhood of 010". The male taper sockets I made were from a non-magnetic stainless steel.
A few links to the machine rebuild and the spindle construction. The first page of the rebuild link has some good pictures of the as received machioe and spindles. Hopefully this answers questions.
Rick
RoninB4
Under My House
-Slide? Odd.
-Based upon your brief description it doesn't sound like there's much of a problem with dis-similar metals provided they're not left in assembly for long and/or the presence of moisture. The acids in some species of wood can also promote etching/corrosion but I'm sure you're aware of this. A simple disassembly and cleaning should be sufficient to prevent this.
-Runout of .010" certainly isn't precision and if the taper isn't precisely matching, it won't lock as a regular taper would. But that doesn't really matter if the assembly is held together by a threaded fastening. I might suggest that the runout may be due to a mismatched taper having a narrow ring of contact with each other, this is just speculation but does seem as though it would greatly affect the finish with it "bouncing". A proper taper is supposed to locate as well as lock.
-Fairly soft material in the 300 series. Not a bad choice but it does have a tendency to gall on itself so using a SS threaded fastener/nut with it can be somewhat problematic if both SS components are in contact with each other. I'd advise using a very thin film of something like anti-seize, any type of grease, or even milk of magnesia (don't laugh we used it in the Air Force) to prevent galling and/or micro-welding. This and the regular disassembly/cleaning should be enough. If corrosion develops a very light application of 600 grit cloth is in order.
-Didn't find much in photos about the tapered spindles until Page 4. Had thought some photos closer than 6 feet away would better depict your application, I guess not. What I did see showed some fairly rusted spindles that will likely clean up nicely but was a bit surprised at the proportions of taper-to-drum. Seems like a small/short taper in relation to the working length of sanding drum, perhaps I'm just using metal working machinery design as my yardstick. Still, it seems as though that makes it even more important for the tapers to have a proper contact area by matching the tapers as best as possible. Runout from mismatch over that length I would expect to have vibration that increases the further out you go. A taper in a female socket can still be calculated with two different sized ball bearings, a depth mic, and a simple trig calculation. It's entirely up to you whether the male tapers you make are good enough or not. Hope this was of some help. I'm about 300 miles West of you, have a machine shop and CAD software if I can be of further assistance.
john.k
Brisbane Qld Australia
Indian made replica parts for antique motorcycles are notorious for tapers being wrong ,and buyers of these junk parts then attempt to make them fit by lapping the taper to the shaft ......ruining their shaft as well.
RoninB4
Under My House
-A new piece of info to file away for future reference. Even info that's unrelated to the topic is useful to someone like me. Thanks for adding that.
