Material/Lifting hand truck
ching0n
Been wondering about how to attach a winch to my hand truck and came across a few ideas that look easy to build for anyone looking for a project. In my world they are handier than your typical lift table w/o a pallet jack footprint. I think a 3-in-1 truck is best suited to modify if not starting from scratch:
Bolt on affair using unistrut:
Ready made but easy to modify your typical one:
Easy to replicate using unistrut or angle iron:
easy to replicate using
Muckin_Slusher
Abitibi
If you're just looking for ideas, this is an ice auger handler I built for an older friend. I wanted downpressure as well as lift so I did sort of a capstan winch?
Gets the handle sort of out of the way, although that's done better with the second example you posted.
Just used solid round bar chunks in the strut (no bearings).
IndyGarage
Indy
I like the idea of that homebuilt one. I'm always trying to wrestle heavy stuff into the back of a truck. And you could pretty easily put that into the back of the truck if you like.
The Hero one looks good too, but it looks a little more bulky and heavy. I like the nylon strap and the fact that it has a pulley at the top that aligns the strap to the lift mechanism and allows the winch to be out of the way. I looked it up, they cost $1289, which is a little expensive, but probably worth it if you use it a lot.
I have an old Vermette 512 lifter that I normally use for stuff like that. It's much more substantial than the hand truck, more like a mini forklift. Genie makes some similar products. They will lift 500 lbs 12 feet high. I used it to successfully lift some 500lb steel beams about 8 feet up to hold a sagging floor last fall but that was about the limit of it's capability. They are great for putting heavy stuff into a truck. I see them on Craigslist occasionally.
They cost something like $4000 new and I don't know if they are even still available - I bought it for something like $200 because it needed some welding repairs. The guy I bought it from sold used office furniture and used it to lift steel office desks on pallet racks.
It's nice but there are two problems - first because of the design it doesn't go flat on the floor in the down position. You have to have about 3-4 inches of clearance under the item you are lifting. I can usually solve that with blocks of wood. Second, it's not really all that portable. It weighs probably 120 lbs and is pretty large and bulky. I have gotten it into the pickup, but it's a bit of a job. Here's a picture of one, you can add sections to the mast up to 12 feet high.
gregs
I have on of those with 12 feet of mast. Works good for stacking stuff on the pallet rack and all kinds of other lifting needs. I found that some 2" pipe (I think) fits inside of the "forks" allowing you to extend it past the end of the casters. I have moved it but use a trailer. I see yours has the big wheels on the back that allows you to lean it back like a hand truck and roll it across the ground and up a ramp into a trailer. Best $100 I spent and its paid for itself 10 times over.
