? Material/spacing for French Cleats ?
soj
North Georgia
I have made/used French Cleats before and used 3/4" plywood for both halves of the cleats.
I have also seen 1X4s (3/4" dressed) used. I am wondering about something less expensive than 3/4" plywood. Any opinions on using MDF, OSB or particle board? Anything else come to mind? I really don't think particle board would be suitable. I know premade metal cleats are available but haven't looked into any yet.
These are going on a new shop wall so vertical spacing ideas are welcome also.
Any help will be appreciated, TIA.
matt_i
A 1x4 @ 8' is less than $5 at a box store....screws could potentially cost more if you get #10 torx drives to hit studs.
PCustoms
VT
Mdf, particle board etc is very likely to fail as there is minimal strength across such a narrow cross section.
Plywood or 1x4
vavet
Ashland, VA
I used 3/4” MDF. I don’t have a lot of weight on it, but I’ve had no issues in about 4 years.
