Math and another compressed air lines idea
chase237
Canyon County, Idaho
In the spirit of beating compressed air lines to death I have a mathematical question about the benefits of volume and dry air.
A couple months ago I found some 1 1/4" copper pipe for a steal, OSH clearance. I picked up 3 10 footers and a couple handfuls of different fittings. All for the express purpose of building a non engineered air separator / dryer, even though I live in a relatively dry climate.
So since a 10 ft length of 1 1/4" equates to 49.1 cu. in. and a 10 ft length of 3/4" equates to 17.7 cu. in. the math comes out to a 10 ft length of 1 1/4" being equivalent to 27.7 ft of 3/4" My plan is use the big stuff right off the compressor then run 3/4" around the shop for the perimeter and drops.
Will this volume be a benefit or a detriment?
I don't use high volumes of air but I do want it dry and the price was right on the copper. Thoughts.
Abeo
Calgary, Ab
A few things to think about:
-Expanding air will lower the temperature, compressing raises it. This may not have a great impact going from 0.5" (or whatever comes off the compressor) to 1.25", but it's in the right direction.
-Slowing air (by having the same CFM in a larger diameter pipe) allows more time for thermal transfer (and hopefully, lowering the air temperature enough to let water condense)
-Larger diameter pipe will have less pressure losses, but if you are already at 3/4, then I don't see much of an impact
Personally, I'd throw on a ****** cooler (or 2) with a drip leg before the air hits the tank. That way you get the most heat (and therefore, water vapor) out of the air before it has a chance to condense in the lines or tank. The extra large tubing after would just be gravy.
bochnak
Mt. Prospect, IL
Ever since I switched from an oil-less to 2 stage 80 gal, my moisture problem is gone. I have a refrigerated air dryer that I never turn on.
So let me ask, what kind of compressor do you have?
teamextreme
Lakewood, CO
The purpose of the long lengths of piping is to reduce the air temp in the lines. While your ten foot stick of 1.25" pipe has the same volume as a much longer piece of 3/4", it doesn't provide the same heat transfer because there is no where near the same surface area to do so.
C
chase237
Compressor is a single stage Porter Cable, 6hp, 80 gallon. 175 psi, 15.6 cfm @ 100 psi.
I think the heat from the single stage may be a contributing factor in the moisture that condenses in the tank.
We just moved so I'm building from scratch and the copper was a great deal.
