MaxJax Installation / Use - Review
Vegaman_Dan
Pacific, WA
With the excellent opportunity to purchase a MaxJax by Danmar during a recent Group Buy here on Garage Journal (Thanks Upshift!), I pulled the trigger and got what I never could have dreamed of having- a real lift. No more jacks and jack stands for me!
At $1800 ($1940 delivered with liftgate service to my driveway), it was a good deal. A bit more than some lifts, a bit less than others. I went with this over others because of the excellent customer service this company has offered and proven time and time again here on Garage Journal. Customer service means a lot, and won my business based on how they treat members here on this forum.
The unit arrived well packed. This has been a concern in the past and it appears they have addressed all the issues. A steel welded frame holds the parts together on a pair of pallets to get the elevation needed. The pump, arms, and other smaller parts are sealed in a large box on top that was reinforced inside against carrier caused damage (something that has been a common problem).
Placement / spacing varies depending on your usage needs. 110-115" between the *back* of the plates / columns for small to midsize, 120" for midsize to small compact trucks, and 125+ for larger. As I would be working on vehicles from a compact pickup to a tiny 3 wheel Cushman, I went with 120". I did consider 123" but that would have made it offset to the garage door opening too much. You can place the column against a wall, but be advised access to the hydraulic quick disconnect will be limited and awkward. The hose will be fine, but you might not be!
Each hole needs to be 7/8" and 4" deep. Residential slabs in my area were 4" per code at the time (1987), and I lucked out that all of my holes were at 4-5.5". I did drill through all the way just in case I had to redo a hole/fastener. A hammer rotary drill is a must. Well, not a must, but being able to drill the hole in 20-45 seconds is worth it to me. I used a 7/8" SDS Plus drill bit for the job. These aren't cheap- $50 for one from Grainger, but it was amazing to watch it do its magic, boring holes in concrete. My mind just boggles at a metal bit drilling through concrete, yet, there it is.
Oh, don't skimp on the hammer you use to drive those Weijet anchors (included) into the concrete. You want some mass to pound them in.
Preparation of the columns was pretty easy. Lay them down on their back (propped up on wood helps to keep them level), lift the carriage to the top and then you can remove the cylinder from the column at the bottom and lift out. It's held in place by gravity and the carriage. You'll need to do this so you can thread in the hydraulic fittings. Use Teflon tape- the tape that was put on there in advance was a bit light and coming off. I replaced it on all fittings with a good quality tape which ensured no leaks. An ounce of prevention really makes a difference here. Put the cylinders back in place and remember to *slide the carriage back down to the base* before you tip the column back up. Some members have nearly lost their fingers because the carriage will slam down with some force. That advice helped me avoid any problems.
Bolting the columns in place was easy. Shims are provided to help level the columns. I used a pair of magnetic levels to guide me. I put them at the top where any shifting would be the greatest. Since my floor is sloped lightly for drainage, it was important to make sure the shims were in place. Danmar recommends noting the number of shims and placement for when you move or return the columns. That's not a bad idea and I might write it on the base with a paint pen next to the holes.
That brings up an interesting point. There is no left or right column. They are identical so it really doesn't matter which one you put where. I might label them with some vinyl stickers if only to keep them straight for myself.
No installation goes without a few ... challenges. In my case, everything fit great. During the initial lift/testing/bleeding process with the lift empty, I discovered that the vertical cylinder going up through the column was more than happy to keep going right up... and into the overhead garage door track! D'OH! It could have been moved to the left or right a few inches to have avoided it entirely, and I should have seen that before drilling the holes. Oh well. The affected track area was an extension piece and not where the door actually rolled, so it was not affected. I didn't have a good mounting if I shortened the track, so I essentially C-notched it with some 3/16" flat bar stock I used a bender I had picked up recently. It now fits around the cylinder nicely and is stronger than the original track.
Does it work? Yes. Once the system was bled, it was pretty easy. Definitely lube up the slides in the columns with white lithium grease as recommended. Greatly helps in avoiding binding.
The Cushman is very narrow, and I had to use the extension pads to get it to fit, but it did and is rock solid. It can't go up that high due to a light bar behind the cab and the overhead beam. I wish that beam wasn't there! But it does get it in the air and that's more than I could do with the jacks and stands earlier without a lot of trouble.
The S10 fits in there as well, but can't lift high either due to the same overhead beam restriction. This is not a limit of the lift, but of my space. I could move the lift colums towards the garage door four feet and get another foot at least of clearance. Since I'll be using this to hold my Spitfire though mostly, it wasn't as big of a deal. The Spitfire's roof is only at 40" compared to the Cushman's 6 foot height or the S10's 7 foot height with light bar.
V
Vegaman_Dan
Pacific, WA
STORAGE:
When not in use, it's easy to forget the lift is even there. I mean, seriously, how do you overlook a 2 post vehicle lift? Surprisingly simple to do. Once you remove the yellow arms with the pins, they are quick to be stored (in my case behind one column) and the power cart with its hoses rolls away to be stored. The columns really don't take up much room and are out of the way. They don't impact my space usage much at all.
OBSERVATIONS:
I love this unit. I am going to get some extra anchors to put in the driveway in front of the garage so I can get a full lift height for some work. Since the columns bolt down very quickly, there is no reason not to have multiple configurations for spacing or access. I might add another set of mountings alongside the garage when that area gets paved for longer term outdoor usage.
I'd like to get a set of covers made for the columns when not in use as well as one for the power cart. I think they would help keep them clean and make them even less intrusive to the workspace.
The rubber washer for the hydraulic oil reservoir leaked badly. The plastic was malformed lightly and the flat washer couldn't seal. I replaced it with a rubber / nitrile O ring which sealed without any issue.
The quick disconnects are not great. They leak a few tablespoons with each disconnect. I would like to replace them with some of the higher quality fittings available from Weatherhead or similar. During operation, these don't leak at all, but only when disconnecting. A rag under the fitting is advisable to speed cleanup.
I wish I could mod the columns. While additional holes would be nice (three are on the column now), having more settings would be helpful. Also, I would like to weld on small hooks to the back of the columns to hold the yellow arms for storage when not in use. Same thing for the lifting pads and extensions. I might weld up a rack out of rebar to hang on the wall to do the same job.
The wheels on the columns wobble. The vertical plates that form the mounting points are not consistent for width and I found it necessary to shim between wheel and flange to keep the wheels vertical without binding on a couple of the mounts. Easy to do with washers, but it's something that could have been caught during manufacture. Or at least add some washers with instructions to shim as necessary.
These black things attract dust! I was wiping them down a lot during assembly. Again, covers would be nice.
More instructions on what fittings go where would be helpful. I was able to figure it out, but assembly order instructions on the fittings and hose on the power cart could ease in assembly. Install the 90 fittings into the pump and distribution valve *first*, then install the hose. I found it helpful to keep one of the 90 degree fittings loose to help get the hose in place, then tighten up. New Teflon tape on all fittings resulted in a no-leak installation.
Might be worth putting some yellow tape or painting the top of the cylinders yellow to be visible and warning you of overhead clearance issues (like the garage door track conflict). Easy thing to add and worth the safety.
Foam 'pool noodles' or similar may make good cautionary devices to put on the roof of your vehicle when lifting to avoid any unfortunate incidents. It's on my list of things to add.
TIP: A handtruck can work well to place the columns easier than the built in wheels if you have to place one column against the wall. Approach it from the front of the column with your hand truck and you can place it exactly where you want without issue. They really are that light.
CONCLUSION: This is a very affordable solution to problems I didn't even realize I had. I can foresee a long and enjoyable use of this lift. It opens up a lot of possibilities that I had never even thought of until I had vehicles at a workable height. Don't hesitate when the opportunity arises to get one of your own. My neighbor spotted it and is already asking if we can put his truck up on there to do some service work. :)
bcradio
New Mexico
I want one :bowdown:
I didn't read everything yet but will. Did you lift your vehicles up to the first notch on the posts or just lift without using the support notches?
COgarage
Colorado
Outstanding Write Up!!!!
I would love to have one of these some day but my garage ceiling is only 10'. That is not bad but I would have to lose the Garage Door Opener to use it effectively.
I still want one of these!!!!
V
Vegaman_Dan
Pacific, WA
Due to ceiling beam restrictions, I can barely get to the first safety hole. That's not a failing of the lift, but of my garage. :)
V
Vegaman_Dan
Pacific, WA
This is the direction I am leaning for a lift. Are there safety locks at these lift heights?
There are three holes set for safety locks at different heights. Some people have drilled additional, and while this would not affect the safety of the unit, it would void your warranty.
Which reminds me- what IS the warranty of this? There's no paperwork beyond an installation manual that comes with it. I think I'll go write the install date on the inside of the column with a paint pen.
kts
MD
Awesome write up and great photos, thank you for posting this!
One day I'm hoping to get one of these but I need to move to a more permanent home first before I invest in something like this. Until then I have this page saved to read and drool over. :)
kamesama980
columbus, IN
Directly from the danmar website: 24 month limited warranty.
I just got one of these too, quite handy. I have a 10' ceiling and installed it under the garage door opener. Even so, my truck (a bit shorter than your S10 apparently) EASILY clears the first safety stop. I'm currently in mad-scientist mode to figure out how to relocate the GDO.
I agree that some sort of racking on the column for the safety bars, pads, and pad extensions would be nice. And a taller cart for the power unit (I'm 6-4, the lift buttons about mid-thigh and release valve is about knee-height).
UPSHIFT
Simi Valley, CA
Vegaman_Dan:3445472,
You can add a locking hole 1/2 way between the base and the first lock and between the top lock and bottom lock. We did this early on for ceiling restricted Customers and did the load calcs to be sure the structure would not be compromised. Please email me if you have any concerns or questions on hole location. Some GJ Gents have done this before..
Thanks,
Gabe
[email protected]
UPSHIFT
Simi Valley, CA
COgarage,
You are in Great Shape with a 10' ceiling.. We designed this lift for the poor guys with 8' ceilings.. :D With 10' it opens your ability to use several types of lifts on the market. You could get a 48" tall car up 68" and that is a good thing.. :beer:
V
Vegaman_Dan
Pacific, WA
Thanks,
Gabe
[email protected]
Excellent. Then I'll see about adding the hole where I need it for my usage in that application.
I'm now saving up to order another set of Weijet anchors for the driveway next. Need to drill a test hole to check depth.
sidwin
got my 1 ft lines. if anyone wants to get it done, i went with 3500 psi aeroquip. then one side is 3/8npt and the other side is 1/2npt. that way i now have no fittings until i hit the quick connect. makes the install so much cleaner. you can also take this time to get the 90 degree elbow put in so your line can lay flat. not a single drop. definitely makes me feel better than having all those fittings. maxjax should have done it backwards. the fittings should have been on the pump side and all the hoses say with the post. that way if there was a leak it would be so much easier to troubleshoot. it would have been nice if they used AN fittings instead of NPT. Those hoses would line up so much easier as well.
Thanks,
Sid
sidwin is online now Report Post
