97dynaglide
I know there are several very long threads that have tips and info spread through out, but I thought one more couldn't hurt.
The instructions say to use a 5/8'' bit to start the holes while the column is in place.
Since the holes in the base are 7/8", that leaves a little more room for an alignment error than I was comfortable with.
What I did was take a 7/8" hole saw bit, replace the standard pilot bit with a concrete bit. Use this to go thru the base plate to create a small 'dimple' (1/8" to 1/4") in the floor for each anchor.
Remove the column, then use the 5/8" to drill down the 2" as the instructions state. Follow up with the 7/8" and the holes will be perfectly in line with the base/column.
