MaxJax Lift Installed
petee_c
KW area, Ontario CANADA
regguy1,
Couple questions.
How tall are u?
What's the height of that stool?
I think this is the same stool on sale here in Canada.
Thx,
Peter 5'10", but sitting on the floor only 35"
R
regguy1
On Mount Olympus with Zeus
regguy1,
Couple questions.
How tall are u?
Thx,
I'm about 5" 10" The stool is an HF cheapie I've never measured it.....
Just went out and measured it, seat is 14" off the floor.
petee_c
thanks, i went out to the store to pick one up. the box says 14 1/8" high.... Don't think I can beat $12, even if I just use the seat and castors. I may cut it down, and try my Flux Core welder and make it 12". My boxster is pretty low to the ground, unless I drive it up on risers or dual lift it.
P
abstamaria
Manila
regguy1, do your arms lift exactly evenly? I have a 1" difference in height between the left and right arms; this seems within Maxjax's tolerance, but I wonder what your experience is.
Many thanks. (BTW, that is a very neat garage you have.)
Andy
R
regguy1
Andy
Thanks.....
Mine are a bit off, the left side usually gets to top first then a second or 2 later the right tops out. It's not very noticable, maybe an inch or so.
If you swap sides with hoses from the power unit that will tell you if the reason is the flow valve (if variation changes sides) although an inch probably isn't worth worrying about. :thumbup:
abstamaria
Manila
Thanks, Regguy, that is reassuring. Yes, I've swapped the lines with no effect. I;ll bleed some more.
Andy
petee_c
My lift, installed Aug 2011 is out by about 1/2" at max lift.
Also note, when I poured my concrete pads, it turns out one post is 3/8" higher than the other one. Oops. No issues noted thus far.
NewShockerGuy
Northern Virginia / DC
How did you drill through the epoxy floor without mucking it up with the max jack install?
I'm getting ready to install mine and dont want to destroy the epoxy...lol
Thank,
-Nigel
