MaxJax problem with bleeder screw...
LWW
SF Bay
I need to call Danmar, but things have been too crazy at work and I haven't been available to call during business hours.
I was going through the normal bleeding process this past weekend and I closed the bleeder screw on one column. When I put a load on the lift and the pump built pressure, it started to weep hydraulic fluid through the bleeder screw.
It seems like there may be a seal that has gone bad.
I'm going to try and make some time in the morning to call Danmar, but thought I might get some suggestions from the crew here.
Any ideas?
Thanks,
LWW
