MAXJAX Question
rbahr
Boston, MA
Hi All,
I just got my MAXJAX and I have a quick question. I mounted the Flow Divider and noticed that there are 2 ports marked 'input' - top left and bottom right- looking head on (unit is bolted to the cart). Does orientation matter for this?
TIA
Ray
Gasket
On mine, both bottom ports are labeled in.
One of the ports has a steel plug in it, while the other 3 have a plastic plug in them that is red plastic which was painted black. From what I remember, 3 of the ports had a plug that a wrench would take off while the steel one needs an allen head bit to take out. If all of the plugs look the same, use you finger nail to scrape a little bit of the paint off of the plugs. The steel one will be look like shiny metal, the others turned red.
The side that has the two plastic plugs should be on the left of the cart if you are looking at the motor side of the cart (the handles would be on the far side of the cart).
R
rbahr
Boston, MA
I think I will go with that - it is possible that folks were sloppy when they stamped 'in'. I will key off the allen keyed plug
Thanks
Ray
gsport
Salem Oregon
when i bought my dannmar four post lift, the instructions didn't match the plugs either.. i called dannmar and they told me which to use...
