Rin Saeki
Set anchors for my MaxJax.
Inside of my small garage ready for anchoring.
I put these bottles of coolant or something in the right angled position confirming the drill and 2 bottles are parallel to hold drills perpendicular to the concrete surface.
According to manufacturer's guidance,I have to drill a hole with a 7/8" (22.225mm)masonry bit but I used a bit smaller 22mm one because we cannot buy any of inch scaled bits in Japan.
According to this,I guess it was required to tighten the nut with massive torque so I could not tighten the wrench by hand.
Used a old genuine muffler abandoned in my garage to extend an wrench.
Could tighten the anchor bolt easily.
Have a look at this picture below.
Right one is done.
Tightening torque was so large that attached washer was terribly deformed and I substituted metal flames for it,which had been connected to 2 of the MaxJax pillars for transportation.
Anyone who set the Wej-it (MaxJax genuine)anchors,did you tightened the nut with
extreme torque like deforming washers?
Right one is done.
