Maxline vs. Fastpipe for compressed air
sansbury
My new building is almost finished and one of the things I wanted to do in here is run fixed plumbing for compressed air.
I'm planning on an Eastwood 3060 scroll compressor. I know these have some quirks but I want a quieter unit that has decent capacity. In terms of applications, the big one will be feeding air to the VMC (4+ scfm @ 100 whenever the spindle is on), probably a smaller plasma cutter, and all the usual miscellaneous shop uses. I don't do painting or sand blasting at this time.
Rapid Air has starter kits for the flexible 3/4" Maxline and rigid 3/4" Fastpipe kits with a 35% discount. Either one seems to have a capacity of 60+ SCFM so plenty enough for me.
The Maxline is about half the price of the Fastpipe, but with the discount either one fits the budget. I feel like the pipe theoretically might look a little cleaner, but not sure it matters that much in the end. I feel like either is going to look a little funky since I have to build a 1/4" per foot slope into it for drainage. Also wondering if the pipe is better for cooling being aluminum vs. plastic. If I do a full loop around the perimeter that will be just over 130'. Not sure if that's long enough that I wouldn't need a separate cooling loop.
FYI I'm open to other systems too, I'm just familiar with the RapidAir products.
ericm
Southern Oregon
A lot of people have had success straightening the maxline by pulling it through an appropriate size PVC pipe. I think both are aluminum core with plastic on the outside and inside.
I think that either a cooler between the compressor and tank, or one post tank, or both would be a good idea.
1/2" ID pipe would give you a pressure loss under 3 psi at 13 cfm and 150' of pipe. 3/4 is probably overkill. It is even more if you do a full loop. The pipe size calculator for Rapid Air recommends a larger size than calculators at say engineering toolbox.
PT Doc
Have you looked at the Prevost air system? It’s very nice and options are endless.
sansbury
No, but it looks sufficiently close to the Rapidair that I wonder if they’re both made in the same plant… similar pricing too.
Hmm, I suppose that could be true. The 3/4” is only like $150 more and considering what this whole shebang is costing me 😵‍💫 that’s kind of a rounding error. But money is still money and I guess there’s no reason to go bigger if there isn’t any good reason to.
SouthernIllinois
I am going with the Rapid Air rigid Fastpipe.
3/4" based on Rapid Air's calculator.
I'm not buying the kit - just the pieces I need.
I prefer the looks of the arrow straight lines and don't want to deal with trying to straighten the flexible stuff.
I am making a Redneck after cooler / moisture trap out of black steel pipe.
I will have a Motor Guard toilet paper filter at the output of the after cooler and Motor Guard filter / regulators at each of my three drops.
Compressor is a new Champion 2-Stage
My Redneck after cooler with Motor Guard TP filter.
The Motor Guard filter regulator I am putting at each outlet
My layout
The compressor will be in a toolroom. It has two windows to provide fresh air and cooling for the compressor and by putting it in an enclosed room, it should help with noise.
Beerhippie
Far NE Oregon
I've installed a fair amount of 3/4" Rapidaire Maxline around here. If it's possible to get it straight, I didn't get the memo.
As for drain grade, why not make the extra investment in a real, refrigerated air dryer? Your tools and equipment will thank you. We have three remote storage/surge tanks scattered around the brewery and they're always bone-dry when I check them.
