Jeff May
I had a Maytag portable A/C give to me.
When I first tried it out it would blow 68 to 70 degree air out. Not great, but I thought it would be ok for the shop. After about an hour it was over 80 in the shop, when I turned it on the shop was 73. It was vented to the outside also.
Are these things worth having looked at to see if there is a problem?
I thought maybe I'd give it a shot of Freon, I'm not an A/C man, but I could not find any fittings to attach a Freon hose to.
I think its an 8000 btu unit.
I did take the cover off and blow out the coils and inside. It didn't seem to bad. I had it sitting on my bench, so after blowing it out I plugged it in and left it run on the bench for about 30 minutes. The temp did drop down to about 63ish .
Is there anything I can look at, check or do to make it work a little better.
If the 63 degree temp is in the ball park I will go ahead and runa vent to exhaust the hot air and water drain.
Any help or suggestions will be appreciated.
Thanks,
Jeff in Hagerstown
Thanks,
Jeff in Hagerstown
